POV-Ray : Newsgroups : povray.general : macro limitation, why? Server Time
24 Mar 2026 19:24:13 EDT (-0400)
  macro limitation, why? (Message 1 to 5 of 5)
Subject: macro limitation, why?
Date: 26 Sep 2001 12:25:00
Message: <4evso9.0s3.ln@micha.riser>
Why does following not parse in POV (3.1):
#macro return1()
        #if (1=1)
         1
#declare one=return1()
#debug "done\n\n\n"
#if (return1()=1)
        #debug "done."
... gives " xxx.pov:3: error: ) expected but # found instead. "
I could not find anything in the docs saying that this is not possible. Is
it working in 3.5beta?
- Micha
Subject: Re: macro limitation, why?
Date: 26 Sep 2001 12:36:16
Message: <0r04rt48gas14781mq454r6vq4jbh699ua@4ax.com>
On Wed, 26 Sep 2001 18:23:32 +0200, Micha Riser <mri### [at] gmxnet>
wrote:
> Is it working in 3.5beta?
no
and I found shortest code for investigate bug
#if(#if(yes)yes#end)#end
I looks like bug with "if" inside "if"
I will report it to povray.beta-test but I'm sure THEY saw this
ABX
Date: 26 Sep 2001 13:53:09
Message: <MPG.161c34c391e7587998968c@news.povray.org>
In article <4ev### [at] michariser>, mri### [at] gmxnet says...
> #macro return1()
>         #if (1=1)
>          1
>         #end
> #end
This is the problem I guess. It doesn't work this way, I don't know why,
probably a bug.
Do it like this and it should work (at least in MP and 3.5):
#macro return1()
	#if(1=1)
		#local out=1;
	#else // just for the case 1 doesn't equal 1 *g*
		#local out=0;
	out
Lutz-Peter
Date: 27 Sep 2001 07:45:46
Message: <3bb3116a@news.povray.org>
[snip]
Try enclosing your calls to the macro in brackets, i.e:
#declare one=(return1());
#debug "done\n\n\n"
#if ((return1())=1)
        #debug "done."
This should allow POV-Ray to correctly interpret the returned value, and
things should work as expected.
Date: 27 Sep 2001 08:35:02
Message: <9b6vo9.n83.ln@micha.riser>
> #debug "done\n\n\n"
> #if ((return1())=1)
>         #debug "done."
> #end
Thanks, this works! It is a bit nicer than the workaround with an extra
variable.
- Micha
