POV-Ray : Newsgroups : povray.general : Vector data output Server Time
25 Aug 2025 01:43:49 EDT (-0400)
  Vector data output (Message 1 to 3 of 3)
Subject: Vector data output
Date: 28 Oct 2011 11:26:21
Message: <4eaac99d$1@news.povray.org>
I'm trying to figure out if it is possible with povray to get the
following additional information for each pixel as a separate text or
image file:
- x,y,z coordinates pixel
- Normal vector
- texture (before application of lightning, etc.)
I have not found a description of something similar in the documentation,
but maybe there are some hidden debug options which can be activated?
Best regards,
                Matthias
Subject: Re: Vector data output
Date: 29 Oct 2011 04:55:08
Message: <4eabbf6c$1@news.povray.org>
Am 28.10.2011 18:56, schrieb Matthias Wieser:
> Hi,
> image file:
I guess you mean the 3D coordinates of the (nearest) object hit.
There are two possible ways of obtaining this information; both will
require you to run the render a second time:
- Use special textures that give you access to the desired information.
A texture with averaged red, green and blue gradients and an
ambient-only (POV-Ray 3.7: emission-only) finish should do.
- Use MegaPOV, which gives you access to this information with its
post-processing features.
Make sure to use a sufficient bit depth for the output image - I suggest
16 bit per color channel, using e.g. PNG - and set the file gamma to
linear (assumed_gamma 1.0, and File_Gamma=1.0 for POV-Ray 3.7 or
Display_Gamma=1.0 for POV-Ray 3.6 / MegaPOV) for this stunt.
> - Normal vector
Ditto, except that the special texture would be an average of three
slope patterns.
For this you will need to use the special-textures approach, as
MegaPOV's post-processing does not help with this. Use the same textures
as for the normal scene, but set the finish to ambient- or
emission-only. Depending on how you want transparency to be handled, you
might also need to change any filter or transmit components in the
pigment as well.
No hidden debug options, sorry.
Date: 1 Nov 2011 17:34:12
Message: <4eb065d4$1@news.povray.org>
>> Hi,
>> image file:
Yes, that's right.
> suggest 16 bit per color channel, using e.g. PNG - and set the file
> gamma to linear (assumed_gamma 1.0, and File_Gamma=1.0 for POV-Ray 3.7
> or Display_Gamma=1.0 for POV-Ray 3.6 / MegaPOV) for this stunt.
Thank you, I will try.
Matthias
