POV-Ray : Newsgroups : povray.general : Bounce vectors Server Time
11 Oct 2025 01:20:13 EDT (-0400)
  Bounce vectors (Message 1 to 5 of 5)
Subject: Bounce vectors
Date: 12 Jul 2011 22:57:20
Message: <4e1d0990$1@news.povray.org>
I'm looking for a way to calculate the bounce off the interior of a sphere...
I have a position, a velocity vector and my sphere is hollow and centered at the
origin.
I'm pretty sure that Velocity=-Velocity is not right, though in my head it seems
logical.
Subject: Re: Bounce vectors
Date: 13 Jul 2011 04:55:08
Message: <4e1d5d6c$1@news.povray.org>
Le 13/07/2011 04:57, Some Yahoo nous fit lire :
> sphere...
> centered at the origin.
> it seems logical.
Velocity := -Velocity is correct only when position & Velocity are
aligned (you came through the center of the sphere, you go back to it)
For other positions, you need to find the intersection point on the
sphere and mirror the velocity in regard to the normal of the sphere at
that point.
Date: 13 Jul 2011 19:03:56
Message: <4e1e245c$1@news.povray.org>
>> sphere...
>> it seems logical.
> Velocity := -Velocity is correct only when position&  Velocity are
> that point.
ok, lets pretend I failed 3D calculus...
Sphere is <0,0,0>,100
I can use VDist to see when the marbles hit  each marble has
position (vector)
velocity (vector)
Date: 13 Jul 2011 19:57:50
Message: <4e1e30fe@news.povray.org>
that's no problem you only need linear algebra ;)
You can use the trace function to find the intersection point
of the precollision path with the target surface. This will also
give you the normal vector (of course, in the case of a hollow
sphere this will just point to the sphere center). Mirroring the
in vector with the surface normal gives you the (inverted) out
vector. Probably the easiest way to do the mirroring is to
rotate 180 degree about the normal using vaxis_rotate.
Date: 14 Jul 2011 02:46:14
Message: <4e1e90b6$1@news.povray.org>
>>> sphere...
head
>>> it seems logical.
t
>> that point.
> position (vector)
> velocity (vector)
	velocity - 2 * dot(velocity, normal) * normal
	Where:
- dot(a, b) := a.x*b.x + a.y*b.y + a.z*b.z is the dot product;
- normal := position / 100 is the unit normal at intersection.
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
