POV-Ray : Newsgroups : povray.general : Is this a bug in 3.7RC3 ? Or am I missing something? Server Time
11 Jun 2026 01:43:01 EDT (-0400)
  Is this a bug in 3.7RC3 ? Or am I missing something? (Message 1 to 10 of 52)
Subject: Is this a bug in 3.7RC3 ? Or am I missing something?
Date: 17 May 2011 20:46:32
Message: <4dd316e8$1@news.povray.org>
OK, I'm either doing something phenomenally stupid, or there's a blatant bug
in isosurface{} in 3.7rc3.
Step 1) Consider the following simple scene:
  #version 3.7;
  global_settings { assumed_gamma 2.2 }
  camera{ location 5 look_at 0 right x*4/3 }
  light_source{<2,4,8>, <1, .8, .6> }
  sky_sphere {pigment {gradient -y}}
  #declare clipper = difference {box {-2 2} box {<0,-3,0> 3}}
  object {clipper pigment {rgbft <0,1,1,.2,.2>} }
I'm declaring an object and displaying it. It is a box with one quarter
taken out. I'm calling it "clipper" because I want to use it to clip another
object.
Step 2) Now add the following object:
  sphere {0 2 pigment {rgb 1}}
Since 'clipper' is parially transparent, you can see the back 3/4 though it
with the front quarter exposed.
Step 3) use 'clipper' to clip the sphere, i.e. modify the 'sphere' object
like this:
  sphere {0 2 clipped_by {clipper} pigment {rgb 1}}
The front part of the sphere is now clipped away by the 'clipper' box, but
the rest can still be seen in the box. Note the shadow cast by the front
right edge of the sphere onto/into the inside of the sphere.
Step 4) Remove the line that shows the clipper box:
  // object {clipper ....
You can now see the (hollow) back 3/4 of a sphere with the opening pointing
at you. You can still see the aforementioned shadow.
So far this is all as I would expect it.
HOWEVER: now do the same thing again, but in step (2), instead of the
sphere{} put this simple isosurface instead:
  isosurface{function{ sqrt(x*x+y*y+z*z) }
        threshold 2 max_gradient 100 contained_by{ box {-5 5} }
     //     clipped_by { clipper }
          pigment {rgb 1}
In steps (2) and (3) I see the exact same thing that I see with the sphere
object. In particular I can see the shadow on step (3) that tells me that I
can see the inside/backside of the isosurface.
But in step 4, the back/inside of the isosurface is gone.
Why?
Subject: Re: Is this a bug in 3.7RC3 ? Or am I missing something?
Date: 18 May 2011 04:09:59
Message: <4dd37ed7$1@news.povray.org>
Have you tried it with 3.6 ?
> Why?
I would not use clipped_by to perform CSG intersection.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 18 May 2011 06:00:01
Message: <web.4dd39775955938cce619b42c0@news.povray.org>
>           pigment {rgb 1}
> Why?
Because you did not read the manual.
See http://www.povray.org/documentation/view/3.6.1/300/
Thorsten
Date: 18 May 2011 07:06:59
Message: <4dd3a853$1@news.povray.org>
>>            pigment {rgb 1}
>> Why?
> Thorsten
hmmm ... I didn't spot the clue. I'm tempted to say the use of or size
clipper ... care to offer another hint ;-)
Date: 18 May 2011 07:20:01
Message: <web.4dd3aa7c955938cce619b42c0@news.povray.org>
> >>            pigment {rgb 1}
> >> Why?
> > Thorsten
The hint about CSG and isosurfaces is at the very end of that page ;-)
Thorsten
Date: 18 May 2011 15:00:57
Message: <4dd41769$1@news.povray.org>
"Thorsten Froehlich" <nomail@nomail> wrote in message
news:web.4dd3aa7c955938cce619b42c0@news.povray.org...
>> >> sphere
>> >> that I
>> >> Why?
>> > Thorsten
> Thorsten
*IF* you are making reference to this sentence:
  "By default POV-Ray searches only for the first surface which the ray
intersects. But when using an isosurface in CSG operations, the other
surfaces must also be found. Therefore, the keyword max_trace must be added
to the isosurface statement. It must be followed by an integer value.
*THEN* I'd like to point out that this sentence is false:
- The back-side of the isosurface IS the first surface the ray intersects
after the sphere is clipped.
- It is in fact found when the 'clipper' object is visible.
It only vanishes after I turn off the clipper object. Even though it is
still the first surface of the sphere that the viewing-ray intersects
(because all surfaces "in front of it" are clipped). Nothing has changed
about the sphere or which of its surfaces should or should not be
intersected by the viewing ray; all that has changed is that I made the
clipper-volume invisible.
Of course there is no reason why 3.7 should conform to the 3.6
documentation. Which makes it a bit disingenous to point people to the 3.6
docs when they ask questions about 3.7 regarding behaviour *that is
definitely in conflict with the 3.6 documentation*.
Date: 18 May 2011 15:15:09
Message: <4dd41abd@news.povray.org>
The sentence is true and correct for 3.6 as well as 3.7. What is wrong is
your interpretation of what you are seeing without knowing the inner
workings of POV-Ray by making assumptions about the inner workings that are
false.
> documentation.
You can be certain POV-Ray conforms to this part of the documentation, be it
3.6 or 3.7.
No.
It certainly helps to read the documentation when being pointed to it,
rather than complain about being helped ... add all_intersections and just
be happy.
	Thorsten
Date: 18 May 2011 20:02:51
Message: <4dd45e2b@news.povray.org>
Am 18.05.2011 21:00, schrieb SGeier:
Well, actually it's not.
The catch is that the back side may be the first surface of the
isosurface /within the clipped_by object/ - but /not/ the first surface
of the isosurface /per se/ - which the ray intersects.
clipped_by is implemented as follows:
(1) The base object's intersection(s) with the ray are determined;
(2) for each intersection it is checked whether it is inside the
clipped_by object.
Any intersections not reported by step (1) are ignored.
Note that strictly speaking the object you're making (in)visible is
/not/ the clipped_by object; rather, the two are independent objects
that just happen to be derived from the same "prototype" object (your
"clipper" object).
Once the ray hits the surface of a partially transparent object, a new
ray is shot from that intersection point in the same direction as the
original ray; with this intersection point being /inside/ the
(non-clipped) isosurface, the back side now is /truly/ the first surface
of the isosurface the ray intersects.
Again, note that the clipped_by object is /not/ a full-fledged scene
object; POV-Ray never performs any intersection tests on it when
shooting rays - it is /exclusively/ used to check whether an
already-found intersection is inside of it.
That's quite a *bold* statement (in any sense, including typographic);
please be aware that /sometimes/ the developers do know POV-Ray better
than the average user ;-)
I'd agree that Thorsten may not be the best diplomat - but technically
he's right: The behaviour you're observing may be surprising, but works
as intended. Maybe the wording in the docs isn't ideal, but aside from
that there's nothing wrong.
Date: 18 May 2011 23:06:05
Message: <4dd4891d$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4dd45e2b@news.povray.org...
>> added
> The catch is that the back side may be the first surface of the isosurface
> /within the clipped_by object/ - but /not/ the first surface of the
> clipped_by object.
Good to know that this is how it is implemented. However this is NOT how it
is documented. Put the above paragraph into the documentation and
implementation and documentation are in agreement.
>> 3.6
I would hope so - that's why I post things here that do not work as
documented.
There's a perennial communications problem between programmers and users: To
the programmer, the code is the end-all and be-all. Whatever the code does
is "true" and if the documentation deviates from it, then the documetation
is wrong. However from the user perspective, the documentation is all there
is - it tell me what is *supposed* to happen and if the observed results are
different then the code is buggy.
I'm happy to go either way - but there IS still a mismatch between
implementation and documentation here.
> he's right: The behaviour you're observing may be surprising, but works as
> intended.
To a user of POV-Ray it does not (can not) matter what the programmers
*intended*. Unless you want every single one of us folks out here to come
here and post so that you can explain every single one of us what you
intended. The only thing that *can* matter to us is what is *documented*.
> Maybe the wording in the docs isn't ideal, but aside from that there's
> nothing wrong.
If the wording in the docs leads the reader to expect behaviour different
from what is implemented, then the wording is far enough from ideal that we
might as well call it false. No part of the documentation indicates that the
back/inside of the isosurface object will be found when the outer clipping
object is made visible (or the clipped object embedded into a transparent
object or any such thing). In the case of the sphere object, it is visible
in both cases, in the case of the isosurface object it is visible in the
one, but not the other case.
If that is "as intended", then this intention needs to be communicated (in
the docs, not here).
Which it isn't.
Date: 19 May 2011 06:59:05
Message: <4dd4f7f9$1@news.povray.org>
> Which it isn't.
if you think it's /that/ out of whack then ... get yourself a login on
the wiki and edit the section to your liking ... i'll even meet you
halfway. i've copied the aforementioned section into a talk page so have
at it
http://wiki.povray.org/content/Documentation_Talk:Reference_Section_4.2
