POV-Ray : Newsgroups : povray.general : Parser messages Server Time
17 May 2026 21:45:23 EDT (-0400)
  Parser messages (Message 1 to 5 of 5)
Subject: Parser messages
Date: 13 May 2011 14:08:38
Message: <4dcd73a6@news.povray.org>
Low priority and not really a "bug", but there's a couple error/warning
messages floating around that aren't really useful (and/or possibly
misleading). I don't think they warrant a bug report, but I'm not sure where
I would report them so that someone can think about them.
The one that triggered this post (and has been around for a metric
forever[*]) is this one:
      Parse Warning: Suspicious expression after rgb.
which I get whenever I do something like this:
     color rgb CHSV2RGB(<n*2,.85,.7>)
Now CHSV2RGB isn't a built-in (it's in colors.inc) - but does that alone
make it "suspicious"? And of course I use it mostly when I have something
algorithmic (place a lot of objects in a circle, say, and color them by
angle). So this error message tends to arise in large quantities, that can
obscure other (legitimate) warnings.
([*] a metric forever is about 20% longer than an imperial forever)
Subject: Re: Parser messages
Date: 13 May 2011 15:07:31
Message: <4dcd8173@news.povray.org>
from colors.inc:
// Converts a color in HSL color space to a color in RGB color space.
// Input:  < Hue, Saturation, Lightness, Filter, Transmit >
// Output: < Red, Green, Blue, Filter, Transmit >
I'd suspect that since it's output has a transmit value specifying rgb
is the problem ... try:
color rgbft CHSV2RGB(<n*2,.85,.7>)
Date: 13 May 2011 15:09:32
Message: <4dcd81ec$1@news.povray.org>
>> where
>> can
> from colors.inc:
oops ... meant to say transmit/filter value
Date: 16 May 2011 12:57:38
Message: <4dd15782$1@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> wrote in message
news:4dcd8173@news.povray.org...
>> where
> I'd suspect that since it's output has a transmit value specifying rgb is
Woah - that may well be it. And it is exactly what I mean with messages that
"aren't really useful (and/or possibly misleading)". If it expects a 3d
vector and gets a 5d one, why can the message not simply say so? "Suspicious
expression after rgb" doesn't tell me what it means with "suspicious".
Hence this post.
Could whoever is messing with the code have a look at some of these odd
messages and make them a little more clear?
Date: 16 May 2011 14:08:56
Message: <4dd16838$1@news.povray.org>
On 05/16/2011 01:57 PM, SGeier wrote:
> "Jim Holsenback"<jho### [at] povrayorg>  wrote in message
>>> where
> Hence this post.
the warning message is valid ... you can turn off the warning stream if
it's troublesome for you. Have you tried rgbft instead of rgb? If that
suppresses the warning then problem solved ... am I correct?
http://wiki.povray.org/content/Documentation:Reference_Section_1.3#Text_Streams
