POV-Ray : Newsgroups : povray.general : SSLT and scaling Server Time
29 Jul 2024 16:32:44 EDT (-0400)
  SSLT and scaling (Message 1 to 6 of 6)
Subject: SSLT and scaling
Date: 16 Feb 2011 18:30:01
Message: <web.4d5c5cf167e175f7f7fe15af0@news.povray.org>
What is the effect of scaling on subsurface values? Are they scaled accordingly
in order to keep the material equivalent (IMO, a half sized wax object is still
made of the same wax with same SSLT characteristics)? If so, what is the
corresponding law? Related to volume?
Bruno
Subject: Re: SSLT and scaling
Date: 16 Feb 2011 20:14:43
Message: <4d5c7683@news.povray.org>
> Bruno
Those values must NOT be affected by scaling, as it would change the
characteristics of the material.
They are thus treated just like media and fading interiors. Scaling
don't affect the density of your media, the fade_distance, the ior, nor
the SSLT parameters.
In the case of SSLT, you tweak the effect using mm_per_unit in the
global_settings, defaulting to 10 => assumes that 1 unit = 1 cm.
If you model using 1 inch per unit, set it to 25.4.
If you model using 1 unit = 1m, set it to 1000.
If you model using units corresponding to a larger length, SSLT becomes
insignificant and should probably not be used.
Date: 16 Feb 2011 21:50:01
Message: <web.4d5c8cb181badc4b34d207310@news.povray.org>
Okay, but isn't it the case that a set of conditions that look great for
portions of an object which are really "thick" end up giving ugly results for
portions that are "thin".  Thus, I imagine good conditions for a big candle
could look ugly for a significantly smaller one.
Date: 16 Feb 2011 21:55:41
Message: <4d5c8e2d@news.povray.org>
True.
Just remembre that the current implementation is only in it's alpha
stage and subect to importent changes in the future.
Date: 17 Feb 2011 04:42:46
Message: <4d5ced96$1@news.povray.org>
Am 17.02.2011 00:25, schrieb Bruno Cabasson:
Yes, if you will. (Actually, what's really going on is more like media:
The effect depends on the absolute distances involved. So strictly
speaking, in order to keep the material equivalent the values are /not/
scaled.)
> If so, what is the
No, related to distance.
Date: 17 Feb 2011 04:49:09
Message: <4d5cef15$1@news.povray.org>
Am 17.02.2011 03:49, schrieb gregjohn:
Yes, that /may/ happen - but remember that a smaller candle /does/ look
different to a larger one when photographed and then scaled to match,
with the light appearing to "bleed" deeper into the wax in the smaller
candle (relative to the candle's total size).
