POV-Ray : Newsgroups : povray.general : Crescent Moon in daylight. Server Time
29 Jul 2024 18:17:58 EDT (-0400)
  Crescent Moon in daylight. (Message 1 to 10 of 13)
Subject: Crescent Moon in daylight.
Date: 11 Jan 2011 10:21:20
Message: <4d2c7570$1@news.povray.org>
Can anyone suggest how to create a Crescent Moon where the unlit part is
not visible?
Regards
Subject: Re: Crescent Moon in daylight.
Date: 11 Jan 2011 10:29:55
Message: <4d2c7772@news.povray.org>
> not visible?
  Cut the unlit part away?-)
Date: 11 Jan 2011 10:31:18
Message: <4d2c77c6$1@news.povray.org>
> not visible?
Intersect a moon-sphere with a shadow-cone ?
(well, it's rather a csg difference)
(get dimensions & distances from wikipedia)
Date: 11 Jan 2011 10:55:01
Message: <web.4d2c7d03db8fc2836dd25f0b0@news.povray.org>
> not visible?
I've done this before. Put your moon and light source outside a semitransparent,
hollow, no_shadow sky sphere, with a black background. If using radiosity, make
sure the outer texture of the sphere is set to opaque black (unless you want the
shadowed side of the moon to be brightly earthlit!)
Date: 11 Jan 2011 12:11:03
Message: <4d2c8f27@news.povray.org>
> not visible?
Use no_radiosity and ambient 0 for the moon,
and fade_power 2 as well as a reasonable fade_distance
for all non-Sun light_sources. You probably want to
ignore Earthshine, otherwwise you require photons
(for crescent moon "Earthshine" is dominated by
light refracted in the atmosphere). During full
moon it's more reflected light (radiosity?) but you
could only notice it during a lunar eclipse anyway.
Date: 11 Jan 2011 12:49:21
Message: <4d2c9821@news.povray.org>
> not visible?
Make your "sky" transparent.
Make sure to set ambient 0 for your moon.
Make sure that your moon is farther away than your sky.
Date: 12 Jan 2011 01:03:02
Message: <op.vo6lq8fqufxv4h@xena>
> not visible?
I think simulation would be the most realistic way. Have a planet with
atmosphere and an iso-surface moon and a sun.
You can play around with mediasky.pov from the sample scenes under
advanced. Or you can download nx_planets from the object collection to
make a planet with atmosphere.
You can also play around with
http://news.povray.org/povray.text.scene-files/thread/%3Cop.u61y64hyufxv4h%40xena%3E/
-Nekar Xenos-
Date: 12 Jan 2011 03:13:55
Message: <4d2d62c3$1@news.povray.org>
news:web.4d2c7d03db8fc2836dd25f0b0@news.povray.org...
> semitransparent,
> make
> want the
...and that works perfectly!
I put a little example code in povray.text.scene-files
Date: 12 Jan 2011 09:41:30
Message: <4d2dbd9a$1@news.povray.org>
On 12/01/2011 8:13 AM, Thomas de Groot wrote:
> "Bill Pragnell"<bil### [at] hotmailcom>  schreef in bericht
>> semitransparent,
>> make
>> want the
> ....and that works perfectly!
Thanks Thomas.
The only problem with this method is that the Moon is coloured by the
Sphere of the Sky (we need a name for this as skysphere is something
else). In your example the sky is too light, in my opinion. But it
example, looked washed out.
For a darker blue sky I got slightly better results by using a small
fade distance and a large colour value but I suspect that I would need
is fine for a gibbous Moon. But when the Moon is a crescent you can see
part away to get the best result.
It is a work-around but all art is artifice.
Thanks to all.
Regards
Date: 12 Jan 2011 10:51:10
Message: <4d2dcdee@news.povray.org>
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d2dbd9a$1@news.povray.org...
> Thanks Thomas.
> else).
That is what happens also in RL...
