POV-Ray : Newsgroups : povray.general : Model Request: Maglev Wind Turbine Server Time
21 Dec 2025 20:52:29 EST (-0500)
  Model Request: Maglev Wind Turbine (Message 1 to 6 of 6)
Subject: Model Request: Maglev Wind Turbine
Date: 20 Sep 2010 15:15:32
Message: <4c97b2d4$1@news.povray.org>
is here someone who can create the 3D model of a Maglev wind turbine? It
should be fairly simple.
http://maglevwindturbine.com
On their website is a video showing such a turbine, but that's a huge one.
I need such a wind turbine, but without command center on top, but with the
same three side panels to catch the wind, and the round concrete base. The
turbine's diameter could be 5 meters, the height maybe 15 or 20 meters. Just
a simple platform with reeling on top, instead of command center, and a
round stairway inside.
he overall color would be plain white, the stairs would be aluminum, the
base a light concrete gray.
And I need it converted into an Autodesk (.3ds) or AutoCad 3D model file
(.dxf). Thanks.
Subject: Re: Model Request: Maglev Wind Turbine
Date: 20 Sep 2010 22:00:21
Message: <4c9811b5$1@news.povray.org>
> (.dxf). Thanks.
You are REALY not at the right place. POV-Ray use a Scene Description
Language based on methematical description of the objects. It don't
produce any mesh that can be exported as a 3DS or DXF file.
While it can use mesh objects, they are normaly created using some other
applications.
Date: 24 Sep 2010 10:20:53
Message: <4c9cb3c5$1@news.povray.org>
Well, I know. But I hoped someone could convert. Is there any new version
out of Crossroads?
Date: 27 Sep 2010 10:16:06
Message: <4ca0a726@news.povray.org>
The problem has been solved. Thanks to everyone. Thread closed.   :-)
Date: 27 Sep 2010 10:41:18
Message: <4ca0ad0e$1@news.povray.org>
Oh no it's not.
How did you do it?
Best Regards,
Date: 1 Oct 2010 16:32:10
Message: <4ca6454a$1@news.povray.org>
I had to learn a bit of 3D Studio Max, at a friend's place. Was hard. And
the import into the house planning software is not 100%, the file is still
faulty. But okay for now.
