POV-Ray : Newsgroups : povray.general : bitwise operator on int ? Server Time
11 Apr 2026 05:43:20 EDT (-0400)
  bitwise operator on int ? (Message 1 to 4 of 4)
Subject: bitwise operator on int ?
Date: 14 Jul 2010 01:03:48
Message: <4c3d4534$1@news.povray.org>
Greetings,
All these years of pov... and it seems I only fail now to find a bitwise
operator for integer.
Is there such things already as a bitwise-AND, bitwise-OR, bitwise-XOR
in the SDL ?
I currently would need a XOR, any suggestion ?
Subject: Re: bitwise operator on int ?
Date: 14 Jul 2010 11:37:55
Message: <4c3dd9d3@news.povray.org>
> in the SDL ?
  Since the SDL doesn't support integers (only floating point), bitwise
operators seem kind of pointless...
Date: 14 Jul 2010 14:22:44
Message: <4c3e0074@news.povray.org>
Le 14/07/2010 17:37, Warp nous fit lire :
>> in the SDL ?
Ok, so I guess you have no objection if I post a patch in p.u.patches
for that purpose on 3.7;
Bitwise operations are sometime useful (just like int()), even if the
result is afterall a floating number (the range with accuracy might be
reduced, but at least it should be fine unless the 52 bits of double
precision mantissa get in the way: for 16 bits, it should still be ok)
Date: 14 Jul 2010 14:31:15
Message: <4c3e0273$1@news.povray.org>
>>> in the SDL ?
Note that such a patch won't make it into 3.7 and likely won't be supported
in any future version of an official POV-Ray with whatever syntax you use.
It may still be interesting to some though, so go ahead, I would say...
	Thorsten
