POV-Ray : Newsgroups : povray.general : Statistic_File in pov 3.7 Server Time
29 Apr 2024 16:41:58 EDT (-0400)
  Statistic_File in pov 3.7 (Message 1 to 3 of 3)
Subject: Statistic_File in pov 3.7
Date: 21 Jun 2010 12:49:22
Message: <4c1f9812$1@news.povray.org>
I have the Statistic_File INI option set to this:
Statistic_File=D:\working\povray\images\povray_statistics.txt
Works fine in 3.6, but in the beta I get an "Cannot open file" error.
Has this option's behavior been changed since 3.6?
http://isometricland.com
Subject: Re: Statistic_File in pov 3.7
Date: 22 Jun 2010 06:03:14
Message: <4c208a62$1@news.povray.org>
Here's the behavior I see on a customized linux-beta37a ...
I have Output_File_Name=/povfiles/ so when I say either +GSstats.txt or
Statistic_File=stats.txt I get a file written to /povfiles/stats.txt
When I change +GS or Statistic_File to /tmp/stats.txt I get the error,
but when I removed the Output_File_Name option the file is written to
/tmp/stats.txt ... Re-added Output_File_Name AND did mkdir /povfiles/tmp
and all was OK fine.
From your post it appears that you're using the Output_File_Name option
... just a guess, but is that so?
Jim
Date: 22 Jun 2010 18:29:26
Message: <4c213946$1@news.povray.org>
> Jim
Yep, that's what I'm seeing too. In addition, if I set:
Statistic_File=true
Then a file called "stats.out" gets created instead, in the same
directory as Output_File_Name.
