POV-Ray : Newsgroups : povray.general : Coloring 3DS files Server Time
28 Sep 2024 09:14:51 EDT (-0400)
  Coloring 3DS files (Message 1 to 4 of 4)
Subject: Coloring 3DS files
Date: 13 May 2010 15:16:56
Message: <4bec5028@news.povray.org>
Interjection of greetings:
The issue: I downloaded some objects in .3ds format.
The problem: When converting it to Pov-ray with Poseray, this is assigned
the same white uniform texture throughout.
The question: How can I assign different materials to each group of items
without having to install 3d Studio? There seems not to be an option in my
version of Poseray.
Any suggestions that do not pass to convert visible / invisible, colorize
and convert each group of the object?
Thanks for your comments and sorry for my poor English language skills
Another interjection of greetings
B. (that does not mean Baal, Bismuth or Brendan) Gimeno
Subject: Re: Coloring 3DS files
Date: 13 May 2010 16:01:33
Message: <4bec5a9d@news.povray.org>
> version of Poseray.
you may use blender to regrouping and reassign materials to faces
Date: 13 May 2010 16:21:30
Message: <4bec5f4a$1@news.povray.org>
> version of Poseray.
Welcome Mr Gimeno (Not Baal)
3DS files come with a MTL file which holds the material information. See
http://nendowingsmirai.yuku.com/topic/1723/t/Wavefront-mtl-file-format-info.html
for more information. If an entry is like:
newmtl SkinBody
Ns 1
Ka 0 0 0
Kd 1 1 1
Ks 0 0 0
That means that the colour is white. You can change the mtl file or
assign colours to the 3ds model in PoseRay. Select a material group and
picker.
I hope this helps.
Best Regards,
Date: 13 May 2010 20:19:13
Message: <4bec9701$1@news.povray.org>
> version of Poseray.
If the mesh comes in groups but only one material then after loading the
3DS model in PoseRay, go to the materials tab and click on tools and
then on Groups->Materials. This way PoseRay will create materials out of
the groups and then you can assign different colors to them.
If the mesh only has one material and one group then you will need an
external editor (like blender) to assign new materials.
FlyerX
