![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
I'm trying to produce the colors of the rainbow inside a #while loop, but to no
avail so far. I need them to progress from red to violet, and I am using the
CHSV2RGB for the conversion, which I thought would make things easier. Still,
all I get is a constant red color in my blob.
Here is the code. The problem is in the blob with the loop (which produces an
ascending spiral):
camera{
location < 0, 150, -1000 >
look_at < 0, 20, 0.000 >
angle 5.000
light_source{ <800,4000, 700> rgb 1 }
sphere {
<0, 0, 0>, 1
gradient y
color_map {
[0.0 color rgb < 01.0, 01.0, 1.0 >]
finish { diffuse 0 ambient 1 }
hollow on
no_shadow
scale 30000
blob {
threshold .0005
#declare Cr = 0;
#declare Mx = 2330;
#declare Rd = 0.1;
#declare Ap = 1;
#declare As = 1;
#declare Vl = 1;
#while (Cr <= Mx)
sphere { <0,0,0>, 1.3 ,1
translate <Cr*Ap*Rd*Rd,Cr*Vl*Rd*Rd*1.3, Cr*As*Rd*Rd>
rotate y*Cr*Vl
pigment{rgbft CHSV2RGB(<((Mx-Cr)/Mx), 1.0, 1.0>)}
#declare Cr = Cr + 1;
___________
My intention here is to produce an ascending spiral with seven turns; each turn
being of a color of the rainbow (or something close to that). The spiral ascends
alright, but the colors don't vary at all.
There's very little documentation on CHSV2RGB, and I found no examples of it in
action, so any help will be greatly appreciated.
Ruy (an extremely absent POVer since 1994, version 2.2)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hello,
The hue is given in degree. In your sample, it goes from 0 degree to 1
degree, giving an almost imperceptible change in coloration.
Change your code to:
#local Hue = (Mx-Cr)/Mx*360;
// Scale to a full circle on the colour wheel
// Adjust if you want to use a smaller or larger range
pigment{rgb CHSV2RGB(<Hue, 1.0, 1.0>)}
OR change your pigment to:
pigment{rgb CHSV2RGB(<((Mx-Cr)/Mx)*360, 1.0, 1.0>)}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah, so Hue varies from 0 to 360 degrees while Saturation and Value vary from 0
to 1. That's a very interesting piece of information. Exactly what I needed to
hear, Alain, merci!
It worked perfectly.
Ruy
> texture {
> Alain
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> hear, Alain, merci!
> Ruy
>> texture {
>> Alain
To find that, you need to look inside colors.inc.
CHSV2RGB internaly calls CH2RGB.
CH2RGB is defined as:
#macro CH2RGB (H)
#local H = mod(H, 360);
#local H = (H < 0 ? H+360 : H);
#switch (H)
#range (0, 120)
#local R = (120- H) / 60;
#local G = ( H- 0) / 60;
#local B = 0;
#break
#range (120, 240)
#local R = 0;
#local G = (240- H) / 60;
#local B = ( H-120) / 60;
#break
#range (240, 360)
#local R = ( H-240) / 60;
#local G = 0;
#local B = (360- H) / 60;
#break
<min(R,1), min(G,1), min(B,1)>
When you look at that code, it becomes obvious that you are using
degrees. CHSL2RGB() also use degrees.
It should be added to the documentation.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Done ...
http://wiki.povray.org/content/Documentation:Reference_Section_7#Color_macros
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Definitely OOC but welcome back.
You have been assimilated, resistance was futile :-)
John
Cogito sum,|| wbu### [at] tznvy pbz (rot'ed) || GPG Key Fingerprint:
ergo sum, || These opinions are mine alone, || 0D9BCF4CF1B71CA2F5F7
cogito || others can find their own || BFBBCBC34EDEAEFCE453
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Done ...
> Jim
Excellent, thank you very much!
> John
Thanks! It's good to be back, even if just for a short while. :D
Ruy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
