POV-Ray : Newsgroups : povray.general : Major speed improvements Server Time
11 Apr 2026 09:12:48 EDT (-0400)
  Major speed improvements (Message 1 to 2 of 2)
Subject: Major speed improvements
Date: 11 Feb 2010 01:56:12
Message: <4b73aa0c$1@news.povray.org>
I found the cause of my speed issues with the clones/reactor room scene
I had taken regular antialiasing
Antialias=On
Antialias_Threshold=0.1
Sampling_Method=1
Antialias_Depth=5
and - in an effort to improve it, set it to...
Antialias=On
Antialias_Threshold=0.001
Sampling_Method=2
Antialias_Depth=5
This resulted in a *lot* of rays.
Sampling method 1 would yield 25 samples, whereas method 2 would be a
maximum of 1089 samples.  And no amount of optimizing my media would
take that any lower.
See here.
http://www.povray.org/documentation/view/3.6.1/223/
Subject: Re: Major speed improvements
Date: 11 Feb 2010 10:31:42
Message: <4b7422de@news.povray.org>
  The idea with method 2 is that, while method 1 always sends a fixed amount
of samples (when the antialiasing threshold is reached), method 2 sends more
samples adaptively as needed, thus resulting in a better antialiasing
quality. If you wanted to reach the same antialiasing quality with method 1,
it would have to send a lot more rays than method 2 (because method 1 is not
adaptive).
  Which method is best suited depends on the scene. Sometimes simply using
method 2 with otherwise default antialiasing settings results in a much
higher-quality antialiasing than with method 1, without considerable increase
in rendering time (and, as said, to achieve the same visual quality with
method 1 a lot more samples would be needed, increasing the rendering time
significantly).
