POV-Ray : Newsgroups : povray.general : Problem with file #read Server Time
28 Sep 2024 11:20:02 EDT (-0400)
  Problem with file #read (Message 1 to 9 of 9)
Subject: Problem with file #read
Date: 27 Jan 2010 02:41:59
Message: <4b5fee46@news.povray.org>
I can't seem to #read using close to the example in
the Documentation. The example below errors that var2
is an undeclared identifier.
I've tried with and without a trailing comma, after
xf5 and before the closing quote
Am using version 3.6.1.c.id8.win32 on WinXP.
Any suggestions much appreciated.
// if first time through, then write file
#if (clock = 0)
 #declare xf1 = 4.30 ;
 #declare xf2 = 5.30 ;
 #declare xf3 = 6.30 ;
 #declare xf4 = 7.30 ;
 #declare xf5 = 8.30 ;
 #declare xf6 = 9.30 ;
#fopen MyFile "shapesA.txt" write
#write(MyFile,"\"ShapesA\",",xf1,",",xf2,",",xf3,",",xf4,",",xf5"\n")
#fclose Myfile
#declare var1 = 1.1 ;
// read from file
#fopen Infile "shapesA.txt" read
#read (Infile, Txt1, var1, var2, var3, var4, var5)
#fclose Infile
#debug concat("\n\nClock = ",str(clock,1,2)," \n")
#debug concat("File read -> ", str(var2,1,1), " \n")
Subject: Re: Problem with file #read
Date: 27 Jan 2010 03:22:07
Message: <4b5ff7af$1@news.povray.org>
"Adam" <ahc### [at] ihugconz> schreef in bericht
news:4b5fee46@news.povray.org...
I think there is a " missing after ShapesA\" in the line above. It should
probably be:
#write(MyFile,"\"ShapesA\"",",xf1,",",xf2,",",xf3,",",xf4,",",xf5"\n")
I don't know if this will fix the problem though.
Date: 27 Jan 2010 04:05:11
Message: <4b6001c6@news.povray.org>
> probably be:
> Thomas
No, as written does make sense. And the file #write works OK
to disk. After the #write section a file appears containing;
"ShapesA",4.3,5.3,6.3,7.3,8.3     as expected.
I remain baffled that the #read doesn't load the string and floats.
Date: 27 Jan 2010 14:13:25
Message: <4b609055$1@news.povray.org>
The reason is that the MyFile (I mean your file) is still open.
   Just use #fclose MyFile
instead of #fclose Myfile
Date: 27 Jan 2010 14:33:32
Message: <4b60950b@news.povray.org>
No, I don't understand.  See below that Myfile
is opened and closed for the #write.  And that
Infile is opened and closed for the #read.
#if (clock = 0)
#fclose Myfile
// read from file
#fclose Infile
Date: 27 Jan 2010 14:37:52
Message: <4b609610$1@news.povray.org>
> #fclose Myfile
> #end
	Pov is case-sensitive, therefore MyFile is different from Myfile...
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 27 Jan 2010 14:48:41
Message: <4b609899@news.povray.org>
You use "MyFile" to open,
but "Myfile" to close,
POV-Ray identifiers are case sensitive,
and hence file "MyFile" is still open.
Again, if we replace "#fclose Myfile"
with "#fclose MyFile" it works as it should.
Date: 27 Jan 2010 16:02:14
Message: <4b60a9d5@news.povray.org>
Now I understand. Thanks Bart !
Date: 27 Jan 2010 16:03:48
Message: <4b60aa33@news.povray.org>
>> #fclose Myfile
>> #end
> Jerome
Well put, Jerome.  I thought either I or Bart was
crazy for a bit there. Now I can see that I need
better glasses.   Many thanks.
