POV-Ray : Newsgroups : povray.general : Is it posible to generate 12bit images? Server Time
30 Jul 2024 06:26:05 EDT (-0400)
  Is it posible to generate 12bit images? (Message 1 to 2 of 2)
Subject: Is it posible to generate 12bit images?
Date: 10 Sep 2009 03:55:00
Message: <web.4aa8afe971a298974de31c730@news.povray.org>
Hi, I am using POV ray for windows, and I am interested in generate images in
12bit, in fact it would be 12 bit per channel, so finally the image would have
36bit(12x3) per sample, 12 per each R G B channel. Is that possible to do?
Thanks!
Subject: Re: Is it posible to generate 12bit images?
Date: 10 Sep 2009 04:18:43
Message: <4aa8b663$1@news.povray.org>
> Thanks!
See section 3.1.2.4 "File Output Options" in the docs.
Quote:
"Most of these formats output 24 bits per pixel with 8 bits for each of
red, green and blue data. PNG and PPM allow you to optionally specify
the output bit depth from 5 to 16 bits for each of the red, green, and
blue colors, giving from 15 to 48 bits of color information per pixel.
The default output depth for all formats is 8 bits/color (16 million
possible colors), but this may be changed for PNG and PPM format files
by setting Bits_Per_Color=n or by specifying +FNn or +FPn, where n is
the desired bit depth."
I however would also like to know whether Bits_Per_Color affects the
alpha channel as well.
-Mike
