POV-Ray : Newsgroups : povray.general : Array scope/persistance and vtransform Server Time
30 Jul 2024 14:28:10 EDT (-0400)
  Array scope/persistance and vtransform (Message 1 to 4 of 4)
Subject: Array scope/persistance and vtransform
Date: 1 Feb 2009 08:40:12
Message: <4985a63c$1@news.povray.org>
I am trying to fill an array with vectors from inside the loop which builds
the vectors, to be used outside of that loop (by a macro which tests ray
intersection, and if so draws a glow).
So far I have been completely unsuccessful, having tried setting the array
up two different ways each producing a different error stating that the one
thing or another is uninitialized.
I have read the FM regarding arrays, but still fail to see their usefulness
if the data they contain isn't portable outside the scope of the loop which
populates them.
I just want a List<T> right about now...
What I am trying to do is this (pseudo code to save space):
declare array
macro
loop
 fill array
endloop
endmacro
use array
If I had my List<T> I could just do:
List<vector> myList = new List<vector>();
while (n < 6)
 myList.Add(<Math.Sin(n),n,Math.Cos(n)>)
 n++;
foreach(vector v in myList)
 testRay(v,cam_pt,myObject)
Is there a way to do this in povray?
My second question: I have an object constructed thusly-I translate an
object(a) into an "object(b) of objects(a)" in one loop, then translate that
"object(b)" into an "object(c) of objects(b)". Is there a way using an array
as specified above, to determine the end position in object(c) of each
object(a) using vtransform (or something)? Am I close?
I've used pov for years, but never consistantly enough to know how to do
either of these two things in SDL.
I am half considering just writing a freaking C# program to dump my vectors
into a file, which I could import into povray...but thats a really ugly
solution.
I would really appreciate any help with this, as these two problems have
plagued me for years in various incarnations across many WIP, including my
most recent. >_<'
thanks,
ian
Subject: Re: Array scope/persistance and vtransform
Date: 1 Feb 2009 09:52:35
Message: <4985b733$1@news.povray.org>
"[GDS|Entropy]" <gds### [at] hotmailcom> wrote in message
news:4985a63c$1@news.povray.org...
>I am trying to fill an array with vectors from inside the loop ... snip ...
> declare array
> macro
> loop
> fill array
> endloop
> endmacro
> use array
Yes:
// Define the macro
#macro YourMacro()
  #local I=0;
  #while (I<6)
    #declare Data[I]=<sin(I),I,cos(I)>;
    #local I=I+1;
// Declare your Array
#declare Data = array [9];
// Call the Macro to populate the array
YourMacro()
// Use the Array (in this case I simply write a
// vector value into the message stream)
#debug concat("Data element 3: <",vstr(3,Data[3],",",3,3),">\n")
Using the #declare directive gives the array global scope wherever it is
declared (so you could equally well declare it within your macro).
> that "object(b)" into an "object(c) of objects(b)". Is there a way using
> an array as specified above, to determine the end position in object(c) of
> each object(a) using vtransform (or something)? Am I close?
If you assign the various translations to variables (or to elements of
arrays), then you can calculate cumulative values. For example, if ObjectA
is translated by a value assigned to array element Data[3], and if ObjectA
is added to a union of objects called ObjectB, which is then translated by a
value assigned to variable ObjectBTranslationVector, then the total
translation is Data[3]+ObjectBTranslationVector.
You can also do something similar with rotation vectors, using the vrotate
function to calculate the total rotation.
Another option is to store entire tranformations (translations, rotations
and scale factors) against identifiers (e.g. as array elements). Entire
transformations can be 'accumulated' using 'transform'.
regards,
Chris B.
Date: 1 Feb 2009 15:45:00
Message: <web.498609837696691ff8450bd80@news.povray.org>
Yeah, I know that feeling ;) Some "foreach" would come in handy, too... oh, I
see you mention that in your post as well...
#declare mySize = 6;
#declare myArray = array[mySize];
> while (n < 6)
#declare n = 0;
#while (n < mySize)
  #declare myArray[i] = <sin(n),n,cos(n)>;
>  n++;
  #declare n = n + 1;
#declare n = 0;
#while (n < mySize)
  #declare v = myArray[n];
  #declare n = n + 1;
See above. It *should* to the job, although I might have added some typos.
It gets somewhat problematic if you need to later add more elements to the array
though: There simply isn't such a thing as a List<T> in POV SDL.
I must confess I haven't a clue what you intend to do. Can you try to rephrase
that?
> solution.
I think at times it's a much more beautiful one ;)
Date: 4 Feb 2009 11:03:54
Message: <4989bc6a$1@news.povray.org>
Just wanted to say thank you to Chris B and clipka, you guys solved it. :-)
ian
> one thing or another is uninitialized.
> usefulness if the data they contain isn't portable outside the scope of
> the loop which populates them.
> declare array
> macro
> loop
> fill array
> endloop
> endmacro
> use array
> while (n < 6)
> n++;
> vectors into a file, which I could import into povray...but thats a really
> ugly solution.
> most recent. >_<'
> thanks,
> ian
