POV-Ray : Newsgroups : povray.general : Wavelet Turbulence Server Time
18 Mar 2026 11:09:20 EDT (-0400)
  Wavelet Turbulence (Message 1 to 2 of 2)
Subject: Wavelet Turbulence
Date: 27 Dec 2008 17:43:04
Message: <4956af78$1@news.povray.org>
I came across this webpage
http://www.cs.cornell.edu/~tedkim/WTURB/source.html the other day.
The authors of the paper are distributing their source code for free. I have
downloaded the package since it purports to export to df3 format. I got it
to compile using MSVC after adding zlib and libpng and making a few small
changes to the png output in image.h. It runs fine but the output goes black
(0 in the density files) after 3 or 4 frames. Nothing like the images on the
website. I was hoping someone else would be interested in taking a crack at
this and seeing if it works with a different compiler.
aanxious to get this to work...
Mike
Subject: Re: Wavelet Turbulence
Date: 28 Dec 2008 22:42:12
Message: <49584714$1@news.povray.org>
Well, I finally gave in and installed cygwin and compiled the source using
the included makefile and it works! I am at a loss for why the output is
completely different using a build made with Visual Studio compared to one
made with GCC. I looked through the code for hours and couldn't find
anything that wasn't standard C++, at least as far as I could tell. I will
post a test render once it finishes its run and can get the df3 files to
work.
Mike
"Mike Hough" <nos### [at] nospamcom> wrote in message
news:4956af78$1@news.povray.org...
> have downloaded the package since it purports to export to df3 format. I
> got it to compile using MSVC after adding zlib and libpng and making a few
> small changes to the png output in image.h. It runs fine but the output
> goes black (0 in the density files) after 3 or 4 frames. Nothing like the
> images on the website. I was hoping someone else would be interested in
> taking a crack at this and seeing if it works with a different compiler.
> Mike
