POV-Ray : Newsgroups : povray.general : output_to_file? Server Time
30 Jul 2024 16:19:07 EDT (-0400)
  output_to_file? (Message 1 to 3 of 3)
Subject: output_to_file?
Date: 15 Dec 2008 17:10:01
Message: <web.4946d4a93bd3391844fd4ef80@news.povray.org>
i've just downloaded pov-ray.  i have an image rendered, but i get a message
that a file was not created because output_to_file is turned off.  where do i
find output_to_file in order to turn it on?
Subject: Re: output_to_file?
Date: 15 Dec 2008 20:27:04
Message: <494703e8$1@news.povray.org>
jiana nous illumina en ce 2008-12-15 17:05 -->
Assuming that you are running under windows.
The first run is just a test run set not to output any image and the
output_to_file flag is temporarily set to OFF. If the image get rendered, then
the installation process was successfull. The default is output_to_file ON.
After that, if you start a render, an actual image file will be created. You'll
also get a message telling you the image's file name and it's location.
You know you've been raytracing too long when you tell stories to your kids that
include stuff like "Once there was a polygon mesh who was very sad because he
was only Gourard shaded."
     -- Taps a.k.a. Tapio Vocadlo
Date: 15 Dec 2008 22:55:00
Message: <web.4947255e326845791d1e1c0@news.povray.org>
Just to make sure: We're talking about the Windows version of POV-ray 3.6.1c I
presume?
First, I suggest checking whether output really wasn't written. Output_to_file
should be on by default, and it should generate a file with the same name as
the scene file (but with a .bmp bitmap file type instead of .pov).
I occasionally get messages saying "no output file was written" for no apparent
reason; it also seems to depend on whether I do a partial render, and/or the
output file type I choose; I haven't found any systematic pattern in it yet.
If the file really isn't written, enter "output_to_file=on" in the field next to
the resolution dropdown combo, just above the editor window. You can enter all
sorts of parameters there to override anything that is in any of POV-ray's
multiple .ini files.
If that solves your problem, you may want to check your .ini files (see
"tools/Edit master POVRAY.INI" and "tools"/Edit PVENGINE.INI") and maybe add
that option to one of them.
