POV-Ray : Newsgroups : povray.general : normal on/off in 2-pass radiosity Server Time
29 Sep 2024 05:19:24 EDT (-0400)
  normal on/off in 2-pass radiosity (Message 1 to 6 of 6)
Subject: normal on/off in 2-pass radiosity
Date: 7 Jul 2008 10:01:09
Message: <487221a5$1@news.povray.org>
Q: when using a 2-pass radiosity render and in the case normals need to be
calculated, where should normal be set to on? In the first pass (saved)? or
the second? or both?
Thanks!!
Subject: Re: normal on/off in 2-pass radiosity
Date: 7 Jul 2008 12:59:51
Message: <48724b87@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:487221a5$1@news.povray.org...
> or the second? or both?
it seems to make more sense having normal on during the 1st pass when your
collecting rad data ..... sometime ago I remember a post that offered if you
don't care about normals just turn it off as it slows things down. I did a
small test and it does indeed.
just my 0.02 worth
Jim
Date: 7 Jul 2008 13:41:07
Message: <48725533@news.povray.org>
  Normals do indeed slow down radiosity, but they also make a difference
if normal perturbations are relevant and visible on the surfaces. Without
'normal on' (and without any actual light source) the surface is rendered
smooth, as if it didn't have any normal perturbation at all.
Date: 8 Jul 2008 03:43:45
Message: <48731ab1$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:48725533@news.povray.org...
>> a
Exactly. In general, I never turn normals on in radiosity for that reason,
and in many scenes it is not a big issue if normals are nor really shown.
However, now that I have a scene where normals would possibly play a part, I
was wondering where to do that. As Jim writes, the 1st pass seems to make
more sense, but it is also collected on a (much) smaller render so, in the
final pass where normals are turned off, are we not going to miss something?
I suppose everything depends on the size difference between 1st pass render
and final render...
Date: 10 Jul 2008 18:20:23
Message: <48768b27@news.povray.org>
Thomas de Groot nous illumina en ce 2008-07-08 03:43 -->
>>> a
> and final render...
> Thomas
If the two passes are at much different scales, then, I think that you must turn
normals on on the second pass, and maybe not on the first. The first pass will
collect low frequencies from the normals, and the higher frequencies will be
collected during the final pass.
Health is merely the slowest possible rate at which one can die.
Date: 11 Jul 2008 08:22:05
Message: <4877506d$1@news.povray.org>
"Alain" <ele### [at] netscapenet> schreef in bericht
news:48768b27@news.povray.org...
> must turn normals on on the second pass, and maybe not on the first. The
> first pass will collect low frequencies from the normals, and the higher
> frequencies will be collected during the final pass.
Hm, yes. That is what I suspected. I have tried the first case and normals
are not really visible. I shall try this out. Thanks for the tip.
