POV-Ray : Newsgroups : povray.general : Linearity of light Server Time
23 Jun 2026 02:37:41 EDT (-0400)
  Linearity of light (Message 1 to 5 of 5)
Subject: Linearity of light
Date: 2 May 2008 08:39:38
Message: <481b0b8a$1@news.povray.org>
Hi.
If, for the rendering of a scene, I use:
Display_Gamma=1
and assuming that the scene is dim enough so there will be no clipping.
If I make the scene twice as bright, by doubling the value of all lights and
ambient values, can I expect that the resulting rendered scene will have all
the pixel values doubled?
Subject: Re: Linearity of light
Date: 4 May 2008 11:50:38
Message: <481ddb4e@news.povray.org>
  There may be other things besides light sources and ambient light which
affects the color of the pixels. Media is one example.
Date: 4 May 2008 17:13:45
Message: <481e2709$1@news.povray.org>
Warp  wrote in message <481ddb4e@news.povray.org>:
Right, there are emitting media, I forgot them.
But if I handle all kinds of light sources, it should be linear, right?
Date: 4 May 2008 19:37:20
Message: <481e48b0$1@news.povray.org>
There are saturation issues if you use bright lights, you can end
up with pixels that are brighter than displayable, which washes out
the highlights. High Dynamic Range Images (HDRI) are not supported
in 3.61, though they are supported in MegaPOV. Also there are
gamma correction issues... a pixel that is half the value of another
pixel is not necessarily half the brightness, it's modified a bit by
hardware. You might try making a test pattern with some
gradient pigments to check the how linear the image gamma
appears with different assumed_gamma values.
Date: 5 May 2008 12:53:28
Message: <481f3b88$1@news.povray.org>
"Tim Attwood"  wrote in message <481e48b0$1@news.povray.org>:
Of course. I explicitly excluded these case in my original question.
My goal is to make the scene dimmer than it should be, and then post-process
it to simulate glare effects.
>						 Also there are
As I wrote, I intend to put both scene gamma and output gamma to 1.
