POV-Ray : Newsgroups : povray.general : #declare final_frame? Server Time
18 Mar 2026 19:52:31 EDT (-0400)
  #declare final_frame? (Message 1 to 4 of 4)
Subject: #declare final_frame?
Date: 28 Jan 2008 09:12:53
Message: <479de2e5@news.povray.org>
Is the any way I can declare the amount of frames in a .pov file for
instance:
#if(Result=Desired_Result)
    #declare final_frame=10
#else
    #declare final_frame=20
According to the docs I can't do it this way. Is there any other way of
doing it? I can't seem to find anything.
Please help...
tnx
-Nekar Xenos-
Subject: Re: #declare final_frame?
Date: 28 Jan 2008 10:30:00
Message: <479df4f8$1@news.povray.org>
Nekar Xenos nous apporta ses lumieres en ce 2008/01/28 09:13:
> instance:
> #else
> #end
> Please help...
> tnx
final_frame must be declared in an ini file or on the command line. It's
considered as a constant.
It can't be changed once the render is started. Please note that the final_frame
value will affect the time differential between each frame. In your case, clock
will change by 0.1 with final_frame =10 between each frames, and by 0.05 with
final_frame =20.
You can add a line like
//+kff 10
//+kff 20
at the start of the file. In the windows version, you can right-click one of the
  comments and select "copy ... to the command line" BEFORE you start the
rendering process.
Coming soon: Windows for Nintendo!
Date: 28 Jan 2008 10:56:46
Message: <479dfb3e$1@news.povray.org>
> instance:
> #else
> #end
> Please help...
Interesting. So you want to increase the number of frames if you still
didn't reach the result you wanted? Here's a trick you could use: render
with 1000 frames or some other super-high amount, and:
#if(Result = Desired_Result)
     #error "Aborting render, reached desired result"
That would render only enough frames :)
By the way, #declare statements should end on a semicolon.
Date: 29 Jan 2008 00:55:56
Message: <479ebfec@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> wrote in message
news:479dfb3e$1@news.povray.org...
>> instance:
>> #else
>> #end
>> Please help...
> #end
Thanks, this should work :)
oops! ;
-Nekar Xenos-
