POV-Ray : Newsgroups : povray.general : A quick rand() question... Server Time
12 Apr 2026 11:25:01 EDT (-0400)
  A quick rand() question... (Message 1 to 10 of 10)
Subject: A quick rand() question...
Date: 22 Oct 2007 12:22:57
Message: <471cce61$1@news.povray.org>
Hey all!
I know the rand()-Stream ist just pseudo-random, not purely random. I
use the same seed-Value, I get the same order of random-values between 0
and 1, so far, so good.
What's with different OS'? I've got a WinXP-PC and recently also got a
MacBook Pro (Intel Based). Since POV-Ray doesn't run natively on
Intel-Based MacBooks (yet), I'm using MegaPOV to have something running
there. ;-) Of course, since it's MegaPOV, the random-stream might be
different again, but if/once the Intel-Based POV-Ray for Mac gets
released, will the streams be identical?
You may argue that this question is purely scientific, when I use random
streams, I'm looking for random-input, so asking how determined it is
might be kinda stupid... Anyways, I figured I'd just ask. Gotta keep
this random-stuff in mind when designing/writing my next images.
Point is: Once there's a new POV-Ray, or you switch to a different OS,
the image might change, and when it's about re-rendering the same
image... I might have to implement my own, SDL-based random thingy,
that'd be a trick to be sure the stuff I want random ("but not really
random") is more or less determined...
Ah, sorry, I'm beginning to babble, I'll stop here. Back to the
question: How determined are the random-streams when talking cross-OS?
Tim
aka "Tim Nikias"
Subject: Re: A quick rand() question...
Date: 22 Oct 2007 14:31:17
Message: <471cec75$1@news.povray.org>
Tim Nikias napsal(a):
> Hey all!
> Regards,
> Tim
It's not a bad question at all. There are multiple streams for the
purpose that you can change a part of the scene without changing any
random values further down the code so I guess the generator is
cross-platform also.
What I'd like to see is a stream that generates new values for each new
render. I have not succeeded using start_chrono as the seed.
Date: 22 Oct 2007 16:10:00
Message: <web.471d0335ce8620b7c150d4c10@news.povray.org>
Perhaps the easiest way to do this is via a text file that is read and
written to with each scene parse.
Just read in the current value from the text file and increment it, use it
and write the new one back to the text file, ready for the next run.
-tgq
Date: 22 Oct 2007 16:30:01
Message: <web.471d071dce8620b7c150d4c10@news.povray.org>
> -tgq
Actually, since you seem you may be using megaPOV, you can try:
#declare AA=seed(val(date("%Y%m%d%H%M%S")));
This should give you a unique seed every time you run it. It seeds from an
integer concatenated from: Year,Month,Day,Hour,Minute,Sec.
-tgq
Date: 22 Oct 2007 16:47:15
Message: <471d0c52@news.povray.org>
  POV-Ray uses its own random number generator function (a linear
congruential generator, if you are interested; see wikipedia).
There's no reason why it would give different values in different
systems.
  No. Always getting the same stream of numbers every time is very useful
for many purposes.
Date: 22 Oct 2007 18:02:29
Message: <471d1df5$1@news.povray.org>
> systems.
Hm, I seem to recall that I once rerendered an image that I made with
POV 3.1 and rendering it now looks different. But maybe I changed
something else as well, thus mixing up the stream...
> for many purposes.
Yup, just need to make sure that you'll actually get the same numbers
even at a later point. ;-)
Tim
aka "Tim Nikias"
Date: 22 Oct 2007 19:26:14
Message: <471d3196$1@news.povray.org>
Why is there nothing in the help about the Date function?
Bryan Valencia
"I'd rather live with false hope than with false despair."
Date: 22 Oct 2007 19:32:50
Message: <471d3322@news.povray.org>
  Because there's no date function in the official POV-Ray?
Date: 23 Oct 2007 05:19:48
Message: <471dbcb4@news.povray.org>
Tim Nikias wrote:
> Hey all!
There is no concern, the random number sequence will always be the same.
	Thorsten
Date: 23 Oct 2007 11:23:48
Message: <471e1204$1@news.povray.org>
Tim Nikias nous apporta ses lumieres en ce 2007/10/22 18:02:
>>> Of course, since it's MegaPOV, the random-stream might be different
>>> again, but if/once the Intel-Based POV-Ray for Mac gets released,
>> systems.
>>> random streams, I'm looking for random-input, so asking how
>>> determined it is might be kinda stupid...
>> for many purposes.
> Regards,
> Tim
Maybe the random algorythm have changed between 3.1 and 3.6. After all, the
default noise generator did change between 3.5 and 3.6.
Politicians are like diapers, they should be changed often and for the same reason.
	Bob Monkhouse
