POV-Ray : Newsgroups : povray.general : Sample source file from POV 3.7 Server Time
20 Nov 2025 23:33:06 EST (-0500)
  Sample source file from POV 3.7 (Message 1 to 9 of 9)
Subject: Sample source file from POV 3.7
Date: 9 Sep 2007 19:12:02
Message: <46e47dc2$1@news.povray.org>
Attached is a sample source-code file from POV-Ray 3.7 - cones.cpp. This is
an example of what we'd need to convert for 4.0 - all the code would need
to be stripped out and re-implemented with the same functionality (this
does not mean that it has to do things the same way - e.g. someone might
have ideas of how to do it more efficiently - but otherwise it's a matter
of understanding how the original code works and making a new version).
-- Chris
Download 'us-ascii' (11 KB)
Subject: Re: Sample source file from POV 3.7
Date: 9 Sep 2007 20:55:00
Message: <web.46e495b96d9a658aa233c63e0@news.povray.org>
ah!  I see this has become a lot more C++ish since the 3.6 source.
> This is
same interface, new implementation.  And, of course, lots of new bugs. :)
Date: 9 Sep 2007 23:52:12
Message: <46e4bf6c$1@news.povray.org>
You should add that we now have vector and color classes as alternative as
well. No more macros needed for that :-)
	Thorsten, POV-Team
Date: 11 Sep 2007 05:48:00
Message: <46e66450$1@news.povray.org>
> is
> -- Chris
Hmm, so cone calculation consists of 16 functions,
and some of the data is being passed globally.
I'd guess to get a handle on re-writing this stuff
you need a good understanding of what the global
data structures are, and what data really gets
passed to and from each function.
Here's a guess at what these functions in cone.cpp do...
All_Intersections
   Return a true value if this cone intersects this
   ray in this thread; and if the cone has intersections
   that are not on the global stack of intersections
   for this thread, add them.
   Input:
   a ray, a stack of intersections, a thread
   Output:
   a boolean, a modified stack of intersections
   -ALSO USES GLOBALLY-
   VEvaluateRay, Clip.empty, Point_In_Clip
Intersect
   Try to find an intersection with a ray in a thread,
   return 0 if none found, 1 for a base, 2 for a cap,
   3 for a side;  Don't intersect base and cap if open, and
   add intersections distances, and type to the array.
   (always) Thread->Stats[Ray_Cone_Tests]++
   (if an intersection found) Thread->Stats[Ray_Cone_Tests_Succeeded]++;
   Input:
   a ray, a thread, an intersection array
   Output:
   A modified intersection array, the number of intersections
   MInvTransPoint, MInvTransDirection, VLength,
   VInverseScaleEq, Test_Flag (CYLINDER_FLAG, CLOSED_FLAG),
   fabs, MAX_DISTANCE, EPSILON, X, Y, Z
Inside
   Return true if point is inside a cone (or cylinder),
   and inverts the result if the cone is inverted.
   Input:
   a vector point, a thread
   Output:
   a boolean
   MInvTransPoint, Test_Flag, CYLINDER_FLAG, INVERTED_FLAG,
   CLOSED_FLAG, EPSILON
Normal
   Return a normal based on the intersection type and location.
   Input:
   a result vector, an intersection, a thread
   Output:
   a result vector with the normal
   MInvTransPoint, Z, Make_Vector, MTransNormal, VNormalize
Translate
   Translate a cone. This function is a minimal call to Transform.
   Input:
   a vector (unused?) and a transform
   Output:
   actions
   Transform
Rotate
   Rotate a cone. This function is a minimal call to Transform.
   Input:
   Output:
   actions
   Transform
Scale
   Scale a cone. This function is a minimal call to Transform.
   Input:
   Output:
   actions
   Transform
Transform
   Transform a cone. This function is a minimal call to Transform
   and a call to Compute_BBox.
   Input:
   a transform
   Output:
   actions
   Transform, Compute_BBox
Invert
   Set the inverted flag for a cone.
   Input:
   none
   Output:
   an inverted flag
   Invert_Flag, INVERTED_FLAG
Cone
   Initialize the default values for a cone in global space,
   and do the same in local space.
   Input:
   none
   Global Output:
   calls INIT_OBJECT_FIELDS, Set_Flag, a bounding box
   Local Output:
   apex and base vectors, apex_radius, base_radius, dist, Trans
   Make_Vector, Create_Transform, Make_BBox, CONE_OBJECT, CLOSED_FLAG
Copy
   Create a new cone object which is a copy of another cone.
   Input:
   none
   Output:
   a pointer to a new cone, and a new transform for the cone
   Destroy_Transform, Copy_Transform
Cylinder
   Set apex_radius and base_radius, and set the cylinder flag.
   Input:
   none
   Output:
   A cylinder flag, a local apex_radius and base_radius
   Set_Flag
Compute_Cone_Data
   If this cone is really a cylinder call Compute_Cylinder_Data
   instead. Throw a degenerate exception if apex and base are
   nearly equal. Swap base with apex if base is larger. Calculate
   and perform a transform that will result in a standard cone.
   Input:
   none
   Output:
   dist, Trans, apex, base, apex_radius, base_radius, a bounding box
   VSub, VLength, VInverseScaleEq, VScale, Compute_Coordinate_Transform,
   POV_EXCEPTION_STRING
   nearly equal. Calculate and perform a transform that will
   result in a standard cylinder.
   Input:
   none
   Output:
   dist, Trans, a new bounding box
   VSub, VLength, VInverseScaleEq, Compute_Coordinate_Transform,
~Cone
   Destroy a cone. This function is a minimal call to Destroy_Transform.
   Input:
   none
   Output:
   none
   Destroy_Transform
Compute_BBox
   Make a new bounding box.
   Input:
   none
   Output:
   a new bounding box.
   Make_BBox, Recompute_BBox
Date: 11 Sep 2007 06:02:12
Message: <46e667a4@news.povray.org>
Hmm, where do you see global data in the cone code?
	Thorsten
Date: 11 Sep 2007 09:57:22
Message: <46e69ec2@news.povray.org>
  I think those are member functions and variables of that class, not
globals.
Date: 11 Sep 2007 18:33:28
Message: <46e717b8@news.povray.org>
There may have been globals in the vanilla-C days, but this source
doesn't have globals.  I see no variable definitions outside of the
functions, which is where the globals would be lurking.
John
Date: 12 Sep 2007 00:12:47
Message: <46e7673f$1@news.povray.org>
I think this might be a terminolgy thing,
this class is accessing data elements of
other classes.  If the implementation of
those other classes changed significantly,
then this class may malfunction, but more
important, it makes it hard to read or
to re-write.  All the things I marked as
global are at least non-local, they need
to be looked up by someone new to the
program.  Has anyone written any
documentation?
Date: 28 Sep 2007 18:59:24
Message: <46fd874c$1@news.povray.org>
> -- Chris
You really used proper OOP this time! :) That METHODS "thing" was ugly.
I can't wait to get my hands on the new code. I'm particularly very
interested in the new state file; would give some *proper* checkpointing
on my BOINC project (I did one hell of a hack to save to (uncompressed)
file only when BOINC tells me to and create the PNG when the render is
done).
