![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In the following scene I am trying to create a macro that builds a wall
between two points. I am having trouble with the transformations. You'll
see that it works for the current input points, but doesn't work for all
points. I was wondering if anyone might help with getting the
transformations right. Thanks!
#include "math.inc"
#include "transforms.inc"
#ifndef (Included)
#declare Vect1 = vrotate(<20,-20,20>, <0,0,0,>);
#declare Vect2 = vrotate(<-10,10,-10>, <0,0,0,>);
camera
up y
right x * image_width / image_height
location <0, 0, 0,> + vrotate(<0,0,-1,>,<15,-15,0,>) * 64
look_at <0, 0, 0,>
camera
orthographic
sky y
up y * 64 * image_height / image_width
right x * 64
location vrotate(-z,<0,0,0,>) * 128
look_at 0
sky_sphere {
gradient y
color_map {
[0.0 rgb <0.6,0.7,1.0>]
[0.7 rgb <0.0,0.1,0.8>]
light_source
<3000, 6000, -7000>
rgb 1
parallel
#macro StretchyWall(Point1, Point2, Width, Height)
union
intersection
plane
y,0
rotate x * 85
translate z * Width/2
plane
y,0
rotate x * -85
translate z * -Width/2
box {<-1/2,0,-Width/2,>, <1/2,Height,Width/2,>}
#local Vector = Point1 - Point2;
scale x * vlength(Vector)
// Here's where I need help
Shear_Trans(x, vrotate(y,<0,0,-(90-VAngleD(Vector,y))>), z)
rotate z * (90 - VAngleD(y,Vector))
rotate y * VRotationD(x,<Vector.x,0,Vector.z,>,y)
translate ((Point1 + Point2)/2)
#ifndef (Included)
sphere
Vect1, 1
pigment {color Red}
sphere
Vect2, 1
pigment {color Red}
object
StretchyWall(Vect1, Vect2, 4, 8)
pigment {color White}
#declare Axis_Markers = union
sphere
0,0.005
pigment{color rgb <0,0,0,>}
cylinder
0,x,0.005
pigment{color rgb <1,0,0,>}
cylinder
0,y,0.005
pigment{color rgb <0,1,0,>}
cylinder
0,z,0.005
pigment{color rgb <0,0,1,>}
object
Axis_Markers
scale 32
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I will subjest you to change the way you create your box
Cause you use not the appropriate variables for orient your wall.
(you cant orient your wall by not using the section parameters ..)
Hence
if you condider your defining your wall as
point A .. the point in the middle of the depht of your wall (corner bottom
left)
point B .. the point on the middle of depht of wall (corner up right)
then your wall will be in that direction and shear in the Y direction
hence
CREATE_WALL (point A, point B, Lenght, Depth) , the height is not require
cause = yb-ya
hence
box {0, lenght*x+depth*z+height*y}
will create thet right dimension wall
translate z*depth/2 ...will places it at good origine for orient it
Angle between x and AB is define by
Vangle(y, <xb,yb,zb>-<xa,ya,za>) will give you the angle
hence rotate y * Vangle(y, <xb,yb,zb>-<xa,ya,za>) * pi/180 ..will place your
wall
translate <xa,ya,za> will place it
news:web.467736f6ab9c0994f850a8b00@news.povray.org...
> #include "math.inc"
> #ifndef (Included)
> camera
> up y
> look_at <0, 0, 0,>
> camera
> orthographic
> sky y
> right x * 64
> look_at 0
> sky_sphere {
> pigment {
> gradient y
> color_map {
> light_source
> <3000, 6000, -7000>
> rgb 1
> parallel
> #end
> union
> intersection
> plane
> y,0
> rotate x * 85
> plane
> y,0
> rotate x * -85
> #end
> #ifndef (Included)
> sphere
> Vect1, 1
> pigment {color Red}
> sphere
> Vect2, 1
> pigment {color Red}
> object
> sphere
> 0,0.005
> cylinder
> 0,x,0.005
> cylinder
> 0,y,0.005
> cylinder
> 0,z,0.005
> object
> Axis_Markers
> scale 32
> #end
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A shearing transform combines rotations and scaling.
The length of the new axis vectors are the scaling
factors, and the directions of the vectors are the
rotations. I moved the box to rest one end on the
origin so that you know where it is after stretching...
then the new x axis is just with one point translated
(subtracted) to rest on the origin, and contains the
wall length scaling. The yaxis is still up, so that is
just y still. The new z axis is a vector which is perpendicular
to the wall, that is: it is perpendicular to the new x and y axis.
With math that is the cross product, and POV has
that function as vcross. The vnormalize function makes
sure that the length of that vector is one, so that there is
no scaling. So then you apply the shear, and translate
the wall to sit it on Point1.
intersection {
plane { y,0
rotate x * 85
plane { y,0
rotate x * -85
box {<0,0,-Width/2,>, <1,Height,Width/2,>}
#local xaxis = Point2 - Point1;
#local yaxis = <0,1,0>;
#local zaxis = vnormalize(vcross(xaxis,yaxis));
Shear_Trans(xaxis,yaxis,zaxis)
translate Point1
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
