POV-Ray : Newsgroups : povray.general : Screwy render times in a #switch in animation. Server Time
23 Dec 2025 11:49:19 EST (-0500)
  Screwy render times in a #switch in animation. (Message 1 to 7 of 7)
Subject: Screwy render times in a #switch in animation.
Date: 30 Jan 2007 22:20:32
Message: <45c00b00@news.povray.org>
GROUP O'FRAMES  RENDER TIME TOTAL FOR 160x120's
Frames 1-192:   70 secs [sic]
Frames 192-200  19 secs
Frames 190-200  14 min
Frames 199-200  6 secs
Frames 1-380    (>8 hr)
Frames 1 to 192 are a box with an image map (previous frames, already
rendered). It renders lightning fast.
Frame 193ff are an innocent-enough scene, nothing to choke a render when it
renders several frames by itself.
But when I do some of the box-frames first and then go to my scene, povray
takes three minutes a frame to render to do it!
Any ideas?
--------START OF CODE SNIPPET --------------
#declare clockeee=clock;
#include"duelcaptions11.pov"  // just a macro with my caption system
#switch (clockeee)
#range (0/180,8/180)
        #local
this_name=concat("/home/greg/images/charanim080",str(frame_number,-3,0) )
box{<0,0,0.75> <4,3,0.75>
        pigment{image_map {png this_name map_type 0 once } scale<4/3,1,1>}
        finish{ambient rgb 1}
        translate<-0.65,-0.5,0>
        transform{cameratransform}
#break
#range (8.001/180,28/180)
        #include "chartest03.pov" // a scene with boxes & blobs
        captionmacro(14,18,clockeee,180, "caption","caption ","")//
        captionmacro(19,23,clockeee,180, "caption","caption","caption")//
        captionmacro(24,28,clockeee,180, "caption","caption ","caption")//
#break
...etc...
Subject: Re: Screwy render times in a #switch in animation.
Date: 31 Jan 2007 13:00:00
Message: <web.45c0d88f26d2c6dd40d56c170@news.povray.org>
I tried the same thing with povray 3.6.1c.icl8.win32 on a slower laptop,
yes, using windows.  Here the lumps of frames tell the story more
coherently, and I even switched what was happening in scene 1. Scene 1 now
has a fancy proximity pattern effect calculated for every frame.
Frames   CPU time,  what's rendered
183-188  9.58 s, 6 frames of scene 1
184-189  9.63 s, 6 frames of scene 1
185-190  9.61 s, 6 frames of scene 1
186-191  9.54 s, 6 frames of scene 1
187-192  9.56 s, 6 frames of scene 1
188-193  21.4 s, 5 of 1, 1 frame of scene 2
189-194  34.0 s, 4 of 1, 2 frames of scene 2
190-195  44.9 s, 3 of 1, 3 frames of scene 2
191-196  56.8 s, 2 of 1, 4 frames of scene 2
192-197  69.2 s, 1 of 1, 5 frames of scene 2
193-198  4.78 s, 6 frames of scene 2
194-199  4.88 s, 6 frames of scene 2
195-200  4.82 s, 6 frames of scene 2.
Thus, in an "animation render session," if it has more than one set of scene
files to parse, the render time is greatly slowed.  On a large animation
left overnight on a linux box, this effect was snowballing to make 3 minutes
of
render per frame! But stopping the render there and starting again leaves no
worries.
So any tips on how to avoid this problem?  Is there something wrong with
setting up alternate scenes in an animation with the #switch command?
Date: 31 Jan 2007 20:44:03
Message: <45c145e3$1@news.povray.org>
I'm not 100% sure, but if some of your frames call a macro
that is #included once but called multiple times during a single frame, it
may be accessing that file multiple times... so pasting the macro
into the main file could speed things up.
Date: 1 Feb 2007 12:40:00
Message: <web.45c2251f26d2c6dd40d56c170@news.povray.org>
Consider:
#switch (clock)
#range(0,a-0.0001)
#include "File_for_scene_01.pov"
#break
#range (a,b-0.0001)
#include "File_for_scene_02.pov"
#break
#range (b,1)
#include "File_for_scene_03.pov"
#break
Now, for animation rendering sessions of frames equivalent to these clock
values:
(0,a), there are no worries
(a,1), there are no worries.
But for any c and d, c<a<d :
(c,d) there is a 10-100x slowup in render speed per frame once the povray
animation routine hits clock>a.
This is surely the case of my specific and complicated
File_for_scene_0X.pov's.
Now the question is, Why?
If it were a bug in povray, you'd think others would complain.  Or I would
see it happen with the most simple File_for_scene_0X.pov.  I tried it with
a few spheres and saw no worries.
If it were something in my SDL that were poorly designed, what could it be?
And I'm actually doubtful here, too, as rendering it in two distinct chunks
shows no slowups.  Is there a better design for switching between frames?
Date: 1 Feb 2007 12:58:31
Message: <45c22a47$1@news.povray.org>
Does POV-Ray actually release back to the OS any memory it has
allocated? Perhaps you are paging/swapping due to large chunks of memory
thru which data structures are suboptimally allocated? Check how much
physical memory you're using when it's slow, and how much paging is
going on?
     You know it's time to trim your beard when your
     wife stops calling you Husband and starts calling
     you Husbollah.
Date: 1 Feb 2007 14:15:00
Message: <web.45c23b0026d2c6dd9356f54f0@news.povray.org>
Or this one...
http://news.povray.org/povray.animations/thread/%3Cweb.43fce6995f972968fc5d75160@news.povray.org%3E/
Date: 1 Feb 2007 14:40:00
Message: <web.45c241c326d2c6dd9356f54f0@news.povray.org>
I don't know what happend to my first reply but it was a link to this
thread:
http://news.povray.org/povray.animations/thread/%3Cweb.45827829b0256beac77a5930@news.povray.org%3E/
"Charles C" <nomail@nomail> wrote:
> Or this one...
