![](/i/fill.gif) |
I have a mesh2 object I want to shoot photons at...
#declare my_object=mesh2{
vertex_vectors{
144,
<-5.510035,-2E-6,14.84191>,
material{MyMaterial}
photons
target
refraction on
reflection on
collect off
The MyMaterial is:
#declare GreenPlatetex =
material // GreenPlatetex
texture
pigment
color rgbft <0.27451, 0.741176, 0.156863, 0.45, 0.75>
finish
ambient 0.2
specular 0.4
roughness 0.01
conserve_energy
reflection
0.15 , 0.25
fresnel off
falloff 1.0
exponent 1.0
metallic 0.0
interior
ior 1.35
caustics 1.25
dispersion 1.25
dispersion_samples 10
In global setttings' photons block, I have the following:
photons
count 20000
jitter .4
radius ,1.5
And as a light source I have
light_source {
<0.0, 0.0, 0.0>
color rgb <1.000, 1.000, 1.000>*1.4500
translate <0.984692, -14.212549, 19.073553>
photons
refraction on
reflection on
I'm sure the light source's emissions can find the object for I can see the
object quite fine.
So I have
- photons block in global_settings
- the object I want photos shot at is marked as a target
- a light source that must emit photons
However, ZERO photons are generated. There is no parsing message that
photons are being shot - I briefly see
Photons Sampling 0x0
then it is gone and the scene starts rendering. There is also no mention of
photons in the scene statistics after it has finished rendering. I'm using
the official Povray 3.1 windows version to attempt this.
What I've already tried:
- no autostop statement as recommended by the docs
- increasing global photon count (I've gone up to 2000000 from the 20 000
shown here, still zero photons shot).
- I've also tried specifying by global photon density - lower densities also
result in zero photons being shot.
- I've tried specifying lower and lower values for density on the object as
well - no results.
It this because I'm trying to shoot photons at a mesh2 object (with
no "inside"?)
Why am I seeing absolutely no photons shot? I see no parsing error messages.
Any ideas?
Stefan
![](/i/fill.gif) |
