POV-Ray : Newsgroups : povray.general : Twist an isosurface Server Time
5 Aug 2025 22:07:32 EDT (-0400)
  Twist an isosurface (Message 1 to 10 of 13)
Subject: Twist an isosurface
Date: 19 Dec 2006 00:03:17
Message: <45877295$1@news.povray.org>
Is there any way to apply a linear twist to an isosurface?
What I'm after is to twist the heart iso, by about 30 degrees, (+/- 15)
along the Y axis.
Subject: Re: Twist an isosurface
Date: 19 Dec 2006 03:26:08
Message: <4587a220$1@news.povray.org>
Hash: SHA1
> along the Y axis.
	Replace x by (x * cos (f (y)) + z * sin (f (y))
	Replace z by (-x * sin (f (y)) + z * cos (f (y))
	Where f is a function that defines the way you want the surface to
twist (the simplest being K*y for some constant K).
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
iD4DBQFFh6Idd0kWM4JG3k8RAvd0AJiagT8lHXsA0eBixWRAozGS8TawAJ4oBbo1
4ZEwfkyQZMASWwlP5vDOqQ==
=T0fP
-----END PGP SIGNATURE-----
Date: 19 Dec 2006 03:54:00
Message: <4587a8a8@news.povray.org>
  Instead of replacing them, wouldn't it be simpler to call the function
with those parameters?
Date: 19 Dec 2006 20:22:09
Message: <45889041$1@news.povray.org>
#ifndef (SolidHeart)
    #ifndef (TwistHeart)
     // Original untwisted version
     #declare Heart_Function = function { f_torus
(y-pow(abs(x),Sharpness)*Bend, z*1, x, 0.8,0.1) }
    #else
      //Twisted version
      #declare K = 1; //Not sure where to set this yet, try 1.0
      #declare f = function {K*y}
      #declare Twist_x = function(x,y,z,f) //<-- Errors here with "expected
parameter identifier, function identifier found instead"
                         {x * cos (f (y)) + z * sin (f (y))}
      #declare Twist_z = function(x,y,z,f)
                         {(-x * sin (f (y)) + z * cos (f (y))}
      #declare Heart_Function = function { f_torus (y-pow(abs(x * cos (f
(y)) + z * sin (f (y))),Sharpness)*Bend,
cos (f (y))*1),
sin (f (y))),
                                                   0.8,0.1) }
  #else
    #declare Heart_Function = function { f_sphere
(y-pow(abs(x),Sharpness)*Bend, z*2, x, 0.6    ) }
Date: 20 Dec 2006 07:07:09
Message: <4589276d$1@news.povray.org>
Hash: SHA1
	Replace this line with:
#declare Twist_x = function(x, y, z)
	You can't pass a function identifier as a parameter to another
function, but you don't need to to be able to call it (huh, does
that sentence make sense?).
		Jerome
iD8DBQFFiSdtd0kWM4JG3k8RAonfAJ91MyMpKoIaopYBBFFfHQ3B8jLriwCgklTx
yztdKmeOg8vou6y2VdCXH4E=
=vYKm
Date: 20 Dec 2006 09:29:09
Message: <458948b5$1@news.povray.org>
I guess not :)  I'm still lost.  Here's the current implementation
    #else
      #declare K = 1;
      #declare Twist_x = function (x,y,z)
                         {x * cos (f (y)) + z * sin (f (y))} <-- "Invalid
number of parameters, 1 supplied, 3 required.
      #declare Twist_z = function (x,y,z)
(y-pow(abs(Twist_x),Sharpness)*Bend,
                                                   (Twist_z*2),
                                                   (Twist_x,
                                                   0.8,0.1) }
  #else
Date: 20 Dec 2006 15:42:03
Message: <4589a01b@news.povray.org>
Hash: SHA1
	The problem is in the declaration for f. Try one of the following
instead:
#declare f = function {K*x}
or
#declare f(y) = function {K*y}
		Jerome
iD8DBQFFiaAad0kWM4JG3k8RAqoAAKCSVOVlop8PR1C/SnG41ZPLxY9PpwCgmcYj
jZBew4IDM7tRDhN0j2gxWs0=
=pKXr
Date: 20 Dec 2006 22:52:48
Message: <458a0510$1@news.povray.org>
> instead:
> or
> #declare f(y) = function {K*y} <-- This one errors, wants an '=' not '('
      #declare K = 1;
#declare Twist_x = function (x,y,z) {( ( x * cos (f(y))) + (z * sin
(f(y))) )}
      #declare Twist_z = function (x,y,z) {( (-x * sin (f(y))) + (z * cos
(f(y))) )}
                                                   Twist_z,
                                                   Twist_x,
                                                   0.8,0.1) }
Very frustrated.. :(
Date: 21 Dec 2006 01:19:20
Message: <458a2768$1@news.povray.org>
Hash: SHA1
>> instead:
>> or
	Uh, yes sorry it should have been:
#declare f = function (y) {K*y}
>       #declare K = 1;
> (f(y))) )}
> (f(y))) )}
>                                                    Twist_z,
>                                                    Twist_x,
>                                                    0.8,0.1) }
	Why? Didn't the code you just posted work?
		Jerome
iD8DBQFFiidld0kWM4JG3k8RAh3DAJ0dF0xytvmN7MlW5BoEXTxc/yN1tQCfc0jJ
N45qh28DOPfPJCP7b0mc+94=
=c0cs
Date: 21 Dec 2006 11:30:40
Message: <458ab6b0@news.povray.org>
Nope, it errors out, I'm not finding the error messages, or even where it's
pointing to when it errors, to be all that helpful.
