POV-Ray : Newsgroups : povray.general : Pigment multiplication Server Time
21 Nov 2025 05:37:08 EST (-0500)
  Pigment multiplication (Message 1 to 5 of 5)
Subject: Pigment multiplication
Date: 14 Dec 2006 07:25:15
Message: <458142ab$1@news.povray.org>
Hello,
I would like to know if a pigment using an image_map can be multiplied
by a color and the result applied as a new pigment in a texture. I tried
with a filtered pigment on top of a solid color but it results in a
washed-out pigment even with a white base as below.
material{
texture{pigment {color rgb <1,1,1>} finish{ambient rgb 0}}
texture{pigment {uv_mapping image_map{jpeg "body_01.jpg" interpolate 2
transmit all 0 filter all 1} }}
Thanks,
FlyerX
Subject: Re: Pigment multiplication
Date: 14 Dec 2006 10:16:35
Message: <45816ad3@news.povray.org>
I don't have time to write out the source, but I can suggest a possible
solution if you are looking for a quick answer.  Use your image map as a
pigment function, and then you should be able to directly multiply the
output of the function by whatever scalar you want.  The function and
its multiplied scalar can then be declared as a new pigment function.
Hopefully one of the pros can help get you setup with this approach if
you have any trouble.
Skip
Date: 14 Dec 2006 12:15:00
Message: <web.4581856fe92a14b7c150d4c10@news.povray.org>
> Skip
Hopefully this can help:
//declare image map as a function
#declare PIMAGE = function {pigment{image_map {jpeg "body_01.jpg"
interpolate 2}}
#declare Mult=rgb <1,1,1>; //multiplier colour
//r,g,b components need to be calculated individually as functions can't
carry vectors:
#declare FRed=function(x,y,z) {PIMAGE(x,y,z).red  *Mult.red}
#declare FGrn=function(x,y,z) {PIMAGE(x,y,z).green*Mult.green}
#declare FBlu=function(x,y,z) {PIMAGE(x,y,z).blue *Mult.blue}
//assemble using average: (colours multiplied by 3 so they average to 1)
#declare Pig=
pigment{average
  pigment_map{
    [function{FRed(x,y,z)*3} color_map{[0 rgb 0][1 rgb <1,0,0>]}]
    [function{FGrn(x,y,z)*3} color_map{[0 rgb 0][1 rgb <0,1,0>]}]
    [function{FBlu(x,y,z)*3} color_map{[0 rgb 0][1 rgb <0,0,1>]}]
-tgq
Date: 14 Dec 2006 15:27:07
Message: <4581b39b$1@news.povray.org>
>> Skip
> interpolate 2}}
> carry vectors:
> #declare Pig=
> pigment{average
>   pigment_map{
> -tgq
Thanks for the code. I think it should work but when I try to use in
POV-Ray 3.6.1 (Win32) the FRed declaration stops with "Expected operand,
colour identifier found instead". After reading about the function on
the documentation I could not see what was wrong. I though that maybe
POV-Ray though it was a color instead of a float so I enclosed the
PIMAGE().red and Mult.red in parenthesis but that did not work.
FlyerX
Date: 14 Dec 2006 15:55:00
Message: <web.4581b99fe92a14b7c150d4c10@news.povray.org>
> FlyerX
Oops, didn't test before I posted.  A couple of errors.  First I missed a
bracket on the function declaration.  Second, I guess Mult can't be passed
as a colour and extract the colour channels like that.  Instead you can
predetermine them:
interpolate 2}}}
#declare MR=Mult.red;
#declare MG=Mult.green;
#declare MB=Mult.blue;
carry vectors:
#declare FRed=function (x,y,z) {PIMAGE(x,y,z).red*MR}
#declare FGrn=function (x,y,z) {PIMAGE(x,y,z).green*MG}
#declare FBlu=function (x,y,z) {PIMAGE(x,y,z).blue*MB}
#declare Pig=
pigment{average
  pigment_map{
-tgq
