![](/i/fill.gif) |
I'm certain this has been asked before, but I can't seem to find it (or
figure it out from the docs).
All of my user defined functions return a float value. How can I write
a function that returns a 3d vector?
The context is simply a pigment block. What I want is something like this:
#declare f1=...
#declare f2=...
#declare f3=...
pigment {color rgb <f1(x,y,z), f2(x,y,z), f3(x,y,z)>]
Of course, I'd be happy declaring only 1 function if it allowed me this
functionality (no pun intended!).
...Chambers
![](/i/fill.gif) |
![](/i/fill.gif) |
>#declare f1=...
>#declare f2=...
>#declare f3=...
The docs for 3.6 say:
3.2.1.6.5 Declaring User-Defined Color Functions
Right now you may only declare color functions using one of the
special function types. The only supported type is the pigment
function.
What you can do is have three separate pigments, each generated from one
function, and average them
#declare R = pigment {function {f1(x,y,z)}
colour_map{[0 rgb 0][1 rgb <3,0,0>]}}
#declare G = pigment {function {f2(x,y,z)}
colour_map{[0 rgb 0][1 rgb <0,3,0>]}}
#declare B = pigment {function {f3(x,y,z)}
colour_map{[0 rgb 0][1 rgb <0,0,3>]}}
sphere {0,1
pigment {average
pigment_map {
[1 R]
[1 G]
[1 B]
By averaging three pigments that are on different colour channels, the
brightness gets divided by 3. That's why we triple the brightness.
E.g. if the output colour of a particular pixel is white, we'd get that
by the fact that (<3,0,0> + <0,3,0> + <0,0,3>)/3 = <1,1,1>.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
![](/i/fill.gif) |
Never mind, I figured it out. Code below ;)
...Chambers
#declare f1=...
#declare f2=...
#declare f3=...
#declare p1=pigment{f1(x,y,z) color_map {[0 color rgb 0][1 color rgb x*3]}
#declare p2=pigment{f2(x,y,z) color_map {[0 color rgb 0][1 color rgb y*3]}
#declare p3=pigment{f3(x,y,z) color_map {[0 color rgb 0][1 color rgb z*3]}
#declare p_final = pigment {
average
pigment_map {
[1 p1]
[1 p2]
[1 p3]
![](/i/fill.gif) |
