POV-Ray : Newsgroups : povray.general : HDR image and mapping it on to a sphere Server Time
31 Jul 2024 22:10:56 EDT (-0400)
  HDR image and mapping it on to a sphere (Message 1 to 5 of 5)
Subject: HDR image and mapping it on to a sphere
Date: 28 Sep 2006 20:10:01
Message: <web.451c64334936cd20ce79570f0@news.povray.org>
I decided to test how HDRI gets wraped onto a sphere. It turned out that it
does it not so well :/ (it happens with any HDRI and any size of sphere)
Is there any solution?
http://img143.imageshack.us/img143/5183/hdritesttgaup0.jpg
Subject: Re: HDR image and mapping it on to a sphere
Date: 28 Sep 2006 20:55:00
Message: <web.451c6e319f6ff81ce79570f0@news.povray.org>
Sorry, forgot about material code:
       image_map {
              hdr
             "c:BlenderTextureshdr02dh006lp.hdr"
             once
             interpolate 2
             map_type 1
     finish {
          ambient 1.0
   diffuse 0.0
Date: 28 Sep 2006 21:15:00
Message: <web.451c72fa9f6ff81ce79570f0@news.povray.org>
never mind :) I got it. For HDRI MegaPov has special map_type that equals 7
Date: 28 Sep 2006 22:58:56
Message: <451c8bf0@news.povray.org>
"motorsep" <nomail@nomail> wrote in message
news:web.451c72fa9f6ff81ce79570f0@news.povray.org...
> 7
Make sure your map-type matches your image type as HDRI probes of various
types are found on the web.  The special map_type 7 is for mapping angular
maps to a sphere.  Angular maps are circular in shape and look similar to a
direct picture of a mirror ball, but the two should not be confused, as they
are quite different.  For an angular map, the distance from the center of
the image corresponds linearly to the angle of the line of sight, whereas
with a mirrorball image, the angles get crunched together as the angle
increases.  With angular maps, less resolution loss occurs at the higher
angles (depending on how it is assembled however).  Several probes from Paul
Devbec's site (don't have the link onhand) are angular and can be used with
the map-type 7.  Mirrorball images can't be used directly, they must be
converted to either angular or longitude-latitude and mapped appropriately.
Longitude-latitude is probably the most common type to be found, and the
only one I like to use (all the light probes I have made my self are in this
format).  This corresponds to the traditional spherical mapping of a
rectangular image to a sphere (it doesn't require a special mapping type),
the x coordinates correspond to the 'longitude' or east-west angle and the y
coordinates correspond to the 'latitude' or north-south angle.  With
lat-long maps, the rectangular image is basically stretched towards the
poles, basically giving 'extra' information, the opposite of mirrorball.
Hope this is of help.  I know there are sites out there that can explain it
better.  I'll try to recover some tomorrow if I can for you.
-tgq
Date: 29 Sep 2006 10:25:00
Message: <web.451d2bb69f6ff81c150d4c10@news.povray.org>
Sorry, Paul Debevec
> -tgq
This HDR Shop tutorial explains the different types a bit with
illustrations.
http://gl.ict.usc.edu/HDRShop/tutorial/tutorial4.html
-tgq
