POV-Ray : Newsgroups : povray.general : Subdividing a spline Server Time
14 Oct 2025 19:05:49 EDT (-0400)
  Subdividing a spline (Message 1 to 7 of 7)
Subject: Subdividing a spline
Date: 14 Jul 2006 09:35:42
Message: <44b79dae$1@news.povray.org>
Is there a way to accurately, or quickly and fairly accurately,
subdivide a spline into equal lengths?  I've written a macro that takes
small steps along the spline and sums up the distance between the steps.
   I then divide this length by the number of segments I want, and
traverse the spline again until this divided distance is reached.  The
lengths always fall short (as well they should as I lose the curvature).
The smaller the step the better the accuracy but the parse times start
getting fairly high.  Less obvious though is that the error increases as
I increase the number of divisions.  It almost seems like its skipping
the last step and distance sum for the segment, and thus they the error
adds up with more segments.
Does anyone have a better approach to this problem or should I scour my
macro for bugs?
Skip
Subject: Re: Subdividing a spline
Date: 14 Jul 2006 15:52:30
Message: <44b7f5fe$1@news.povray.org>
> macro for bugs?
You could google for numerical methods to approximate line integrals.
Tor Olav
http://subcube.com
Date: 15 Jul 2006 06:07:19
Message: <44b8be57$1@news.povray.org>
> macro for bugs?
> Skip
Sounds like first of all you need to define the spline so that equal
deltas of the clock value will produce equal intervals along the spline
I use a fairly crude macro for this which suits natural splines
#macro SmoothSpline( Spline, Grain )
//regularizes the spline definition so
//the distance along the spline will be
//more proportional to the clock value
         #local TL=0;
         #local Ptr=1;#while(Ptr<=Grain)
                 #local TL=
                         TL+vlength( Spline(Ptr/Grain)
                         -Spline((Ptr-1)/Grain) );
         #local Ptr=Ptr+1;#end
         #local L=0;
         spline {
                 natural_spline
                 0 Spline(0)
                         #local L=
                                 L/TL Spline(Ptr/Grain)
Then you can divide the spline into equal lengths using equal clock
deltas.
Date: 22 Jul 2006 00:12:39
Message: <44c1a5b7$1@news.povray.org>
news:44b8be57$1@news.povray.org...
> Skip Talbot wrote:
>> Is there a way to accurately, or quickly and fairly accurately, subdivide
>> a spline into equal lengths?  I've written a macro ...
This seems to work OK.
#include "strings.inc"
#macro Split_Spline(SplA SplB begin_at stop_at rez stype)
   #local Split = concat("#declare ",SplB," = spline {\n",stype,"\n");
   #local c = -rez;
   #while (c <= 1+rez)
      #declare Split = concat(Split,str(c,1,3),",<",
       vstr(3, ABC_spl(c * (stop_at - begin_at) + begin_at),
       ",", 0,3),">\n");
      #local c = c + rez;
   #declare Split = concat(Split,"};\n");
   Parse_String(Split)
#declare ABC_spl = spline {
    natural_spline
    -.25, <0,0,-1>
    0.00, <1,0,0>
    0.25, <0,0,1>
    0.50, <-1,0,0>
    0.75, <0,0,-1>
    1.00, <1,0,0>
    1.25, <0,0,1>
Split_Spline(ABC_spl, "AB_spl", 0, 0.5, 0.25, "natural_spline")
Split_Spline(ABC_spl, "BC_spl", 0.5, 1.0, 0.25, "natural_spline")
Date: 23 Jul 2006 12:25:23
Message: <44c3a2f3$1@news.povray.org>
The length of a spline equals the sum of the straight sub-lengths as the
interval of evaluation approaches zero.
It also equals the integral of the equation of the spline, or the sum of the
integrals of the definable equations of the segments of the spline.
In other words, if you can figure out the equations involved you could
chop the spline up into fewer pieces and come up with an exact answer in
less time.
Date: 23 Jul 2006 12:38:25
Message: <44c3a601@news.povray.org>
// straight line segment evaluation
#macro Len_Spline(Espl begin_at stop_at num)
   #local c = 1/num;
   #local V1 = Espl(begin_at);
   #while (c <= 1)
      #local V2 = Espl( c*(stop_at - begin_at) + begin_at);
      vlength(V2-V1)+
      #local V1 = V2;
      #local c = c + 1/num;
   0
#declare sample = Len_Spline(ABC_spl, 0, 0.5, 10000);
Date: 24 Jul 2006 11:45:00
Message: <web.44c4ea4b3dd920ad3abc2b430@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> wrote:
(snip)
(snip)
one small correction:
>        ",", 0,3),">n");
should be:  vstr(3, SplA(c * (stop_at - begin_at) + begin_at,
etc.
Very nice!  I like the method (and Jim's as well.)  I've been puzzling over
an efficient approximation technique, also, for non-functionally defined
paths.
Thanks, both of you!
Dave Matthews
