![](/i/fill.gif) |
Skip Talbot wrote:
> Is there a way to accurately, or quickly and fairly accurately,
> subdivide a spline into equal lengths? I've written a macro that takes
> small steps along the spline and sums up the distance between the steps.
> I then divide this length by the number of segments I want, and
> traverse the spline again until this divided distance is reached. The
> lengths always fall short (as well they should as I lose the curvature).
> The smaller the step the better the accuracy but the parse times start
> getting fairly high. Less obvious though is that the error increases as
> I increase the number of divisions. It almost seems like its skipping
> the last step and distance sum for the segment, and thus they the error
> adds up with more segments.
> Does anyone have a better approach to this problem or should I scour my
> macro for bugs?
> Skip
Sounds like first of all you need to define the spline so that equal
deltas of the clock value will produce equal intervals along the spline
I use a fairly crude macro for this which suits natural splines
#macro SmoothSpline( Spline, Grain )
//regularizes the spline definition so
//the distance along the spline will be
//more proportional to the clock value
#local TL=0;
#local Ptr=1;#while(Ptr<=Grain)
#local TL=
TL+vlength( Spline(Ptr/Grain)
-Spline((Ptr-1)/Grain) );
#local Ptr=Ptr+1;#end
#local L=0;
spline {
natural_spline
0 Spline(0)
#local L=
L/TL Spline(Ptr/Grain)
Then you can divide the spline into equal lengths using equal clock
deltas.
![](/i/fill.gif) |
![](/i/fill.gif) |
"Jim Charter" <jrc### [at] msn com> wrote in message
news:44b8be57$1@news.povray.org...
> Skip Talbot wrote:
>> Is there a way to accurately, or quickly and fairly accurately, subdivide
>> a spline into equal lengths? I've written a macro ...
This seems to work OK.
#include "strings.inc"
#macro Split_Spline(SplA SplB begin_at stop_at rez stype)
#local Split = concat("#declare ",SplB," = spline {\n",stype,"\n");
#local c = -rez;
#while (c <= 1+rez)
#declare Split = concat(Split,str(c,1,3),",<",
vstr(3, ABC_spl(c * (stop_at - begin_at) + begin_at),
",", 0,3),">\n");
#local c = c + rez;
#declare Split = concat(Split,"};\n");
Parse_String(Split)
#declare ABC_spl = spline {
natural_spline
-.25, <0,0,-1>
0.00, <1,0,0>
0.25, <0,0,1>
0.50, <-1,0,0>
0.75, <0,0,-1>
1.00, <1,0,0>
1.25, <0,0,1>
Split_Spline(ABC_spl, "AB_spl", 0, 0.5, 0.25, "natural_spline")
Split_Spline(ABC_spl, "BC_spl", 0.5, 1.0, 0.25, "natural_spline")
![](/i/fill.gif) |
![](/i/fill.gif) |
"Tim Attwood" <tim### [at] comcast net> wrote:
(snip)
(snip)
one small correction:
> ",", 0,3),">n");
should be: vstr(3, SplA(c * (stop_at - begin_at) + begin_at,
etc.
Very nice! I like the method (and Jim's as well.) I've been puzzling over
an efficient approximation technique, also, for non-functionally defined
paths.
Thanks, both of you!
Dave Matthews
![](/i/fill.gif) |
