![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there any way of twisting a texture? It would make galaxies easier if I
could just use a twist warp on a stretched spherical density for galaxies
because galaxies are more dens near the centre than on the outer arms.
-Nekar Xenos
"The truth is out there"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You could try with a spiral texture map, or by developing a better
user-defined function (which you can then use as a pattern in the
texture map).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Do you mean like "warp {cylindrical}"?
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> -Nekar Xenos
There is no warp option to do this.
But have a look at this function pattern and see if it can help do what you
want:
//START
camera{
up y
angle 45
location y*4
look_at 0
#local PolL=function (x,z){sqrt(x*x+z*z)}
#local PolA=function (x,z){degrees(acos(x/PolL(x,z)))*select(z,-1,1)}
#local A=360;//Rotate 'A' degrees/unit length from center
#local PSPHERE = function {pigment{spherical}}
#local PSPHERE2 = function {PSPHERE(x*2,y,z).gray}
#local PSPHERE3 = function
{PSPHERE2(cos(radians(PolA(x,z)+PolL(x,z)*A))*PolL(x,z),y,sin(radians(PolA(x,z)+PolL(x,z)*A))*PolL(x,z))}
plane{y 0 pigment{function{PSPHERE3 (x,y,z)}} finish{ambient 1}}
//END
-tgq
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> you
> want:
> //START
> camera{
> up y
> angle 45
> location y*4
> look_at 0
> //END
Can functions be used as media densities? If so then this might work.
-Nekar Xenos
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Mike Williams" <nos### [at] econym demon co uk> wrote in message
news:gZx7JFAag+oEF### [at] econym demon co uk...
>>I
> Mike Williams
something that would give the effect of:
density{ spherical scale <1,0.01,0.1> warp{spiral} density_map{[0 colour rgb
0][1 colour rgb 1]}}
-Nekar Xenos
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Perhaps using MegaPOV displace warp instead a regular warp?
Jaime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nekar nous apporta ses lumieres en ce 30/06/2006 04:44:
>> you
>> want:
>> //START
>> camera{
>> up y
>> angle 45
>> location y*4
>> look_at 0
>> //END
Sure can. Anything that you can use as a pigment or for an isosurface CAN be used for
media density.
After all, all pigment pattern are realy built-in functions that return specific
values for specific
coordinates.
WARNING: The consumption of alcohol may lead you to think people are laughing WITH
you.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> be used for media density. After all, all pigment pattern are realy
> built-in functions that return specific values for specific coordinates.
Thanks Alain, I'll give it a try.
-Nekar Xenos
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
