POV-Ray : Newsgroups : povray.general : Twist Warp Server Time
11 Jun 2026 18:57:32 EDT (-0400)
  Twist Warp (Message 1 to 9 of 9)
Subject: Twist Warp
Date: 29 Jun 2006 10:20:52
Message: <44a3e1c4@news.povray.org>
Is there any way of twisting a texture? It would make galaxies easier if  I
could just use a twist warp on a stretched spherical density for  galaxies
because galaxies are more dens near the centre than on the outer arms.
-Nekar Xenos
"The truth is out there"
Subject: Re: Twist Warp
Date: 29 Jun 2006 10:29:35
Message: <44a3e3cf$1@news.povray.org>
   You could try with a spiral texture map, or by developing a better
user-defined function (which you can then use as a pattern in the
texture map).
Date: 29 Jun 2006 10:53:08
Message: <gZx7JFAag+oEFwOM@econym.demon.co.uk>
Do you mean like "warp {cylindrical}"?
Mike Williams
Gentleman of Leisure
Date: 29 Jun 2006 12:15:00
Message: <web.44a3fb7c49282b97c150d4c10@news.povray.org>
> -Nekar Xenos
There is no warp option to do this.
But have a look at this function pattern and see if it can help do what you
want:
//START
camera{
  up y
  angle 45
  location y*4
  look_at  0
#local PolL=function (x,z){sqrt(x*x+z*z)}
#local PolA=function (x,z){degrees(acos(x/PolL(x,z)))*select(z,-1,1)}
#local A=360;//Rotate 'A' degrees/unit length from center
#local PSPHERE = function {pigment{spherical}}
#local PSPHERE2 = function {PSPHERE(x*2,y,z).gray}
#local PSPHERE3 = function
{PSPHERE2(cos(radians(PolA(x,z)+PolL(x,z)*A))*PolL(x,z),y,sin(radians(PolA(x,z)+PolL(x,z)*A))*PolL(x,z))}
plane{y 0 pigment{function{PSPHERE3 (x,y,z)}} finish{ambient 1}}
//END
-tgq
Date: 30 Jun 2006 04:44:32
Message: <44a4e470@news.povray.org>
> you
> want:
> //START
> camera{
>  up y
>  angle 45
>  location y*4
>  look_at  0
> //END
Can functions be used as media densities? If so then this might work.
-Nekar Xenos
Date: 30 Jun 2006 04:48:35
Message: <44a4e563@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:gZx7JFAag+oEF### [at] econymdemoncouk...
>>I
> Mike Williams
something that would give the effect of:
density{ spherical scale <1,0.01,0.1> warp{spiral} density_map{[0 colour rgb
0][1 colour rgb 1]}}
-Nekar Xenos
Date: 30 Jun 2006 04:54:21
Message: <44a4e6bd$1@news.povray.org>
Perhaps using MegaPOV displace warp instead a regular warp?
Jaime
Date: 30 Jun 2006 11:55:07
Message: <44a5495b@news.povray.org>
Nekar nous apporta ses lumieres en ce 30/06/2006 04:44:
>> you
>> want:
>> //START
>> camera{
>>  up y
>>  angle 45
>>  location y*4
>>  look_at  0
>> //END
Sure can. Anything that you can use as a pigment or for an isosurface CAN be used for
media density.
After all, all pigment pattern are realy built-in functions that return specific
values for specific
coordinates.
WARNING: The consumption of alcohol may lead you to think people are laughing WITH
you.
Date: 1 Jul 2006 02:54:46
Message: <44a61c36@news.povray.org>
> be used for media density. After all, all pigment pattern are realy
> built-in functions that return specific values for specific coordinates.
Thanks Alain, I'll give it a try.
-Nekar Xenos
