POV-Ray : Newsgroups : povray.general : Feature request: stars texture Server Time
14 Jan 2026 02:22:53 EST (-0500)
  Feature request: stars texture (Message 1 to 7 of 7)
Subject: Feature request: stars texture
Date: 29 May 2006 00:48:36
Message: <447a7d24@news.povray.org>
Would it be possible to have a procedural texture that is like the leopard
texture, but with random circular spots of different sizes in future versions
of Pov-Ray? It would solve a lot of my space rendering problems.
-Nekar Xenos-
"The truth is out there..."
Subject: Re: Feature request: stars texture
Date: 29 May 2006 01:13:01
Message: <447a82dd$1@news.povray.org>
Try this out:
// Slime's Star Pigment Macro
#macro StarSubPigment(StarSize, StarFrequency)
 crackle
 form <1,0,0>
 #local Cutoff = StarSize * StarFrequency;
 color_map {
  [Cutoff rgb 1]
  [Cutoff rgb 0]
 scale 1/StarFrequency
// minsize, maxsize = size range of stars (some stars will always be smaller
due to nature of crackle pattern)
// starfrequency = how many stars
// variationfrequency = how quickly their size changes
#macro StarPigment(MinSize, MaxSize, StarFrequency, VariationFrequency)
 #local NumSizeSteps = 8;
 pigment
  pigment_pattern
   bozo
   color_map {[0 rgb 0][1 rgb 1]}
   scale 1/VariationFrequency
  pigment_map
   #local StepNum = 0;
   #while (StepNum < NumSizeSteps)
    #local SizeAmnt = (StepNum + .5) / NumSizeSteps;
    #local PreSize = MinSize + (StepNum / NumSizeSteps) * (MaxSize -
MinSize);
    #local PostSize = MinSize + ((StepNum + 1) / NumSizeSteps) * (MaxSize -
MinSize);
    [SizeAmnt
     StarSubPigment(PreSize, StarFrequency)
    [SizeAmnt
     StarSubPigment(PostSize, StarFrequency)
    #local StepNum = StepNum + 1;
sky_sphere {
 StarPigment(
  .0004, // min star size
  .003,  // max star size
  50,    // star density (higher = more)
  10     // variation frequency (higher = star size changes more over nearby
parts of the sky)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 29 May 2006 13:42:12
Message: <447b3274@news.povray.org>
Thanks Slime =)
I've modified it a bit to work as a media density for my galaxy and it looks
quite good.
-Nekar Xenos-
Date: 29 May 2006 14:00:20
Message: <447b36b4$1@news.povray.org>
Same comment from my side: it just looks good!
Sven
Date: 2 Jun 2006 13:06:35
Message: <4480701b@news.povray.org>
Nekar Xenos wrote:
> Thanks Slime =)
> quite good.
I could use something like that...
source, please?
ADB
Date: 4 Jun 2006 03:48:09
Message: <44829039@news.povray.org>
"Anthony D. Baye" <ant### [at] goldsdsmtedu> wrote in message
news:4480701b@news.povray.org...
> Nekar Xenos wrote:
>> Thanks Slime =)
>> quite good.
> source, please?
Ooops!
I changed something again and couldn't recreate it. Will post as soon as I've
fixed it. I'm doing quite a few projects at once so I have very little time for
my own stuff at the moment.
-Nekar Xenos-
Date: 4 Jun 2006 13:32:19
Message: <44831923@news.povray.org>
> Nekar Xenos wrote:
>> Thanks Slime =)
>> quite good.
> source, please?
I hadn't studied it in-deapth when I made those changes but it seems the main
thing is putting form<1,0,0> in a crackle density statement. After some
fiddling I got this without the macro. It looks a lot better than the previos
one IMO.
#include "math.inc"
#include "transforms.inc"
#declare MaxRadius= 1;
#declare Angle= 0;
#declare Radius=1;
#declare
Position=<.1*(clock),1-(2*(clock)*(1-clock)),9-(clock*clock*10)>;//<0,0,-1>;
#declare Counter=0;
#declare Anim=off;
#declare ShowShip=on;
#declare PosLook=Position;
#declare Rotation=z*(90-clock*90);//0 ;// y*(clock*90)
#declare Quality = 2; // 0=Dummy  // 1=Basic  // 2=Full Detail
#declare Cam_Spline = spline {
                           cubic_spline
                           -2, <0, -1, -6>, // control point
                           -1, <0, -.11, -5>, // control point
                           00, < 0, -.01, -4>, // start below ship
                           01, < 0, 0, -2.21>, // behind ship
                           02, < -1, .99, -1.01>, //
                           03, < -.5, .1, -.51>,
                           04, < -.5, .1, -.01>, //
                           05, <0, -.05, .49>, //
                           06, < 0, .01, 0>, // control point
                           07, < 0, -2, 0>, // control point
#declare Ship_Spline = spline {
                           cubic_spline
                           -2, <0, 0, -6>, // control point
                           -1, <0, 0, -5>, // control point
                           00, < 0, 0, -4>, // start
                           01, < 0, 0, -2>,
                           02, < -1, 1, -1>, //
                           03, < -.5, .1, -.5>,
                           04, < -.5, .1, 0>, //
                           05, <0, -.05, .5>, //
                           06, < 0, 0, 0>, // control point
                           07, < 0, -3, 0>, // control point
Spline_Trans(Spline, Time, SkyVector, ForeSight, Banking)
This macro aligns an object to a spline for a given time value. The Z axis of
the object will point in the forward direction of the spline and the Y axis of
the object will point upwards.
Parameters:
Spline = The spline that the object is aligned to.
Time = The time value to feed to the spline, for example clock.
Sky = The vector that is upwards in your scene, usually y.
Foresight = A positive value that controls how much in advance the object will
turn and bank. Values close to 0 will give precise results, while higher values
give smoother results. It will not affect parsing speed, so just find the value
that looks best.
Banking = How much the object tilts when turning. The amount of tilting is
equally much controlled by the ForeSight value.
Usage:
   object {MyObj Spline_Trans(MySpline, clock, y, 0.1, 0.5)}
//[.1 rgb .5][.3 rgb 1][.9 rgb 1][1 rgb 10] // [0 rgb 10][.1 rgb 1][.7 rgb
1][.9 rgb .5][1 rgb 0]
#declare DenStars=density {crackle form<1,0,0> scale.003 /*warp{black_hole 0,1
strength .2}*/ density_map{[.1 rgb 10][.1 rgb 1][.7 rgb 1][.9 rgb .5][1 rgb
0]}}
                     //[.1 rgb .8][.2 rgb 1][.5 rgb 2][1 rgb 10]
#declare DenStars2=density {crackle form<1,0,0>  scale.01 warp{black_hole 0,1
strength 1} density_map{[0 rgb 10][.5 rgb 2][.8 rgb 1][.9 rgb .8]}}
#declare DenSphere=
  density {
    spherical
    turbulence .1
    omega .7
    lambda 3
    density_map {
      [0 color rgb 0]
      [0.5 color rgb <0.01, 0.1, 0.4>/4]
      [0.6 color rgb <0.1, 0.3, 0.5>/2]
      [0.7 color rgb <1.0, 0.5, 0.5>/2]
      [0.8 color rgb <1.0, 0.8, 0.5>]
      [1.0 color rgb 1]
#declare DenSphere2=
  density {
    spherical
    omega .7
    lambda 2
    density_map {
      [0.5 color rgb 0]
      [0.6 color rgb <0.01, 0.1, 0.4>/4]
      [0.65 color rgb <0.1, 0.3, 0.5>/4]
      [0.8 color rgb <1.0, 0.9, 0.5>]
      [1.0 color rgb 1]
#declare DenSphere3=
  density {
    spherical
    turbulence .5
    omega 1
    lambda 2
    density_map {
      [0.5 color rgb 0]
      [1.0 color rgb 1]
#declare DenSpiral=
  density {
    spiral1 1
    //warp{black_hole <.001,0,.001>,.5 strength 1 falloff 3 inverse}
    turbulence .1 omega .7
    lambda 2
    colour_map {
      [0  color rgb 0]
      [0.1 color rgb <0.01, 0.1, 0.3>]
      [0.4 color rgb <0.1, 0.3, 0.5>]
      [0.7 color rgb 1]
      [0.8 color rgb <0.1, 0.3, 0.5>]
      [0.9 color rgb <0.01, 0.1, 0.3>]
      [1 color rgb 0]
#declare DenSpiral2=
  density {
    spiral1 25  scale.1
    //warp{black_hole 0,.2 strength 1.01 falloff .01 inverse}
    turbulence .2
    //lambda 2
    omega .8
    colour_map {
      [0.0 color rgb 0]
      [0.1 color rgb 1]
      [0.7 color rgb 2]
      [0.9 color rgb 1]
      [1.0 color rgb 0]
#declare DenSpiral3=
  density {
    spiral1 1
    warp{black_hole 0,.5 strength 1 falloff 3 inverse}
    turbulence .1 omega .5
    lambda 1
    colour_map {
      [0.2 rgb 0]
      [0.23 rgb .5]
      [0.3 rgb 0]
  rotate x*90
#declare DenSpiral4=
  density {
    spiral1 10  scale.1
    turbulence .2
    //lambda 2
    omega .8
    density_map {
      [0.2 color rgb 0]
      [0.3 color rgb 2]
      [0.4 color rgb 0]
  rotate x*90
#declare ColSpiral=
    spiral1 1
    lambda 2
    colour_map {
      [0 color rgbt <0,0,0,1>]
      [0.1 color rgbt <0.01, 0.1, 0.3,.9>]
      [0.4 color rgbt <0.1, 0.3, 0.5,.5>]
      [0.7 color rgb <1,1,1,.1>]
      [0.8 color rgbt <0.1, 0.3, 0.5,.5>]
      [0.9 color rgbt <0.01, 0.1, 0.3,.9>]
      [1 color rgbt <0,0,0,1>]
#declare SpaceShip =
union{   // space ship
        difference{
                union{
                      sphere{0,1 scale <.2,.2,2>  pigment{colour rgbt
<0,0,0,clock>}normal{bozo clock*2 scale.3 phase clock}finish {reflection
1-clock } interior{ior(1.5-(clock/2))}}
                sphere{0,1 scale <.2,.2,.5> pigment{colour rgbt 1}
 translate -2*z }
                sphere{0,1 scale <.2,.2,.5> pigment{colour rgbt <0,0,1,.9>}
translate 2*z}
                interior {fade_power 1001  fade_distance .1  fade_color <0, 1,
1> }
        sphere{0,1 scale <.1,.1,.05>
                pigment{colour rgbt <0,.5,1,.9>}
                normal{bozo 10 scale .01 turbulence .1 phase clock}
                finish {reflection{0,<.8,.9,1>}}
                interior {fade_power 1001  fade_distance .15  fade_color <0,
.5, 1> }
                translate 1.6*z
        sphere{0,1 scale <.12,.12,.12>
                interior {fade_power 1001  fade_distance .1  fade_color <0, .5,
1.5> }
                translate 1.6*z
        torus{.9,.1 scale .12 rotate x*90 translate 1.6*z pigment{colour rgb
.1}finish {reflection 1 }}
        //sphere {0,1 scale <.3,.3,2.1>pigment{colour rgbt
<0,0,0,clock>}normal{bozo .1 phase clock} finish{reflection clock} }
        light_source {1.6*z  color rgb <1,3,3>*(1-clock)  fade_power 1001
fade_distance .1*(1-clock) }
        //scale .05
        //rotate <-90,15,0>
        //translate Position - ((Position-PosLook)*.1)+(z*.01*clock)
camera {location <-.9,-.01,0>  look_at <2,0,0>}
#if(Quality = 0)
                difference{
                        union{
<2,0,2>}finish {ambient <2,0,2>}}
<0,0,10>} finish {ambient <0,1,2>} translate -2*z }
<0,0,10>} finish {ambient <0,1,2>} translate 2*z}
#end // Quality = 0
#if(Quality=2) // full detail
sky_sphere {
    crackle scale .01
    form<1,0,0>
    //turbulence 10
    //omega .1
    //lambda 25
    color_map {
      [0.6 color rgb 0]
      [0.7 color rgb <0.01, 0.1, 0.4>/5]
      [0.8 color rgb <0.1, 0.3, 0.5>/4]
      [0.9 color rgb <1.0, 0.5, 0.5>/2]
      [0.95 color rgb <1.0, 0.9, 0.5>]
      [1.0 color rgb 1]
sphere{ // surrounding stars
        0,100 pigment {rgbt 1}
        interior {
          media {
           emission 1
           method 3
                                density {crackle scale .001
                                         warp{black_hole 0,100 strength .3}
                                         density_map {
                                                      [0.83 color rgb 0]
                                                      [0.87 color rgb <0.01,
0.1, 0.4>/5]
                                                      [0.9 color rgb <0.1, 0.3,
0.5>/4]
                                                      [0.93 color rgb <1.0,
0.5, 0.5>/2]
                                                      [0.97 color rgb <1.0,
0.9, 0.5>]
                                                      [1.0 color rgb 1]
         hollow
sphere {0, 1
          pigment {rgbt 1}
         interior {
          media {
           emission 10
           //scattering {1, 0.1}
           //intervals 1
           //samples 5
           method 3
           density {DenSpiral   rotate x*90 translate y*.05}
                  density {DenSpiral2  rotate x*90 translate y*.05}
                  density {DenSphere   scale y*.1}
                  density {DenStars}
                  density {spherical density_map{[0 rgb .1][1 rgb 1]} scale
<1.5,.1,1.5>}
                  //scale <1,1,1>
                  media { emission 1 method 3  density {DenSphere2 scale y*.3}
density{DenStars}}
                  media { emission 2 method 3  density {DenSphere2 scale .4}
density{DenStars}}
                  media { emission 1 method 3  density {DenSphere3 scale .1}
density{DenStars2}}
                  media {
           absorption 5
           //emission <0,100,0>
           //intervals 1
           //samples 5
           method 3
           density {DenSpiral3  rotate z*0 translate y*.05}
                  density {DenSpiral4  rotate z*0 translate y*.05}
                  //density {DenSphere scale y*.1}
                  //density {DenStars}
                  density {spherical density_map{[.5 rgb 0][.8 rgb 1][.9 rgb
0]} scale <1.5,.1,1.5>}
                  //scale <1,1,1>
         hollow
         rotate Rotation
#end // #if(Quality=2) // full detail
#if(Quality=1) // Basic
        sphere {0, 1
          pigment {rgbt 1}
         interior {
          media {
           emission 10
           method 3
                  density {spherical density_map{[0 rgb 0][1 rgb .5]} scale
<1,.1,1>}
         hollow
         rotate Rotation
#end // #if(Quality=1) // Basic
#if(Quality=0) // Dummy
    sphere {0, 1 scale y*.1
          pigment {ColSpiral   rotate x*90 translate y*.05}
         finish{diffuse 1 ambient 1}
         rotate Rotation
#end // #if(Quality=0) // Dummy
//light_source {<500,500,-500> rgb 1}
        #if (clock <.5)
                #declare Position=<clock/2,clock*.03,(1-clock)*2>; //
2/Final_Frame
                #declare Radius=Position.x;
                camera {location Position rotate z*(-90*(1-clock)) look_at
PosLook*.9999}
         #if (clock >=.5)
                #declare Angle=Angle+2;
                #declare Radius=Radius-(1/13);
                #declare
Position=<Radius*(sin(radians(Angle))),clock*.03,Radius*(cos(radians(Angle)))>;
PosLook*.9999}
                #declare
Position=<Radius*(sin(radians(-Angle))),clock*.3,2*(1-clock)*Radius*(cos(radians(-Angle)))>;
        #if (Anim)
PosLook*.9999}
        #if (clock=1)
                #declare Anim=off;
//object{SpaceShip scale .05 translate Position -
((Position-PosLook)*.1)+(z*.01*clock)}
#if (Anim)
        //#if (ShowShip)
        //        object { SpaceShip pigment{colour rgb 1000} scale .03
Spline_Trans (Ship_Spline,clock*7 , y, 0, 0) }
        //#end
              location  Cam_Spline(clock*7)   // 0 //
              //look_at <-.01,-.3,.9>
              //translate
<.1*(1-clock),(2*(1-clock)*(1-clock))-1,(clock*clock*4)-3>
              //rotate (90*z)+(z*clock*(90/final_frame))
              look_at  0//<-.01,-.3,.9> //
              //translate  <0,0.4,0.4>
              //Spline_Trans (Ship_Spline, clock*6.5, y, .5, .5)
              //look_at Ship_Spline(clock*7)
#end //  #if (Anim)
