POV-Ray : Newsgroups : povray.general : Nested #switch...#end blocks - strange behaviour! Server Time
30 Sep 2024 11:19:32 EDT (-0400)
  Nested #switch...#end blocks - strange behaviour! (Message 1 to 5 of 5)
Subject: Nested #switch...#end blocks - strange behaviour!
Date: 15 May 2006 18:55:49
Message: <446906f5$1@news.povray.org>
High!
To differentiate multiple camera views according to the clock variable,
I set up a logical structure consisting of nested #switch...#end blocks
- only two levels deep, but a strange effect always occurred: when the
inner #switch block is reached, only either the first or the last
alternative is chosen, but not the ones in between. With this test
script, this means if I start with +k1.1 or +k1.2, I always only got
"One point ????" as #warning output... and, strangely, obviously line 2
is interpreted correctly (see output in line 4)! Is this a bug actually?
#declare clock1 = int(clock);
#declare clock2 = mod(clock*10, 10);
#warning concat("clock2 = ", str(clock2, 1, 0))
#switch(clock1)
   #case (0)
     #warning "Zero!"
   #break
   #case (1)
     #switch(clock2)
       #case (0)
         #warning "One point zero!"
       #break
       #case (1)
         #warning "One point one!"
       #break
       #case (2)
         #warning "One point two!"
       #break
       #else
         #warning "One point ????"
   #break
   #case (2)
     #warning "Two!"
   #break
   #case (3)
     #warning "Three!"
   #break
   #else
     #warning "Oops..."
See you in Khyberspace!
Yadgar
Subject: Re: Nested #switch...#end blocks - strange behaviour!
Date: 15 May 2006 19:22:51
Message: <44690d4b@news.povray.org>
Curious thing... apparently it's the mod() doing it because when I replaced
that part with #declare clock2=1; it works (likewise if clock2=2). And I
haven't a clue why it would happen like that.
Date: 15 May 2006 20:01:26
Message: <44691656$1@news.povray.org>
"Bob H" <omniverse@charter%net> wrote in message
news:44690d4b@news.povray.org...
> replaced that part with #declare clock2=1; it works (likewise if
> clock2=2). And I haven't a clue why it would happen like that.
Hi Bob,
I think it's just the usual rounding errors. If you use the integer part of
the result it works:
    int(mod(clock*10,10))
The cause didn't show up when you used
because this specifies 0 decimal places.
It shows up if you do str(clock2, 1, 30)
Chris B.
Date: 15 May 2006 20:13:05
Message: <44691911@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:44691656$1@news.povray.org...
Wups. Yep, didn't think to look for decimal places.
Date: 15 May 2006 22:40:35
Message: <44693ba3$1@news.povray.org>
> High!
It could be floating point round-off error.  If you absolutely,
positively expect it to be an integer, you really need to put floor()
around any fraction multiplied by anything else.
John
