POV-Ray : Newsgroups : povray.general : Wanted: Elastic Gel Chair Server Time
11 Jun 2026 20:26:09 EDT (-0400)
  Wanted: Elastic Gel Chair (Message 1 to 4 of 4)
Subject: Wanted: Elastic Gel Chair
Date: 13 May 2006 23:02:04
Message: <44669dac$1@news.povray.org>
Greetings.
I am in need of agel-alike elastic, couchy chair or seat. Seen from each
side, it should have a rectanglish shape, like a rectangle touching with its
small side the ground. The shape should have round corners.
Who can help me?
Subject: Re: Wanted: Elastic Gel Chair
Date: 15 May 2006 08:41:39
Message: <44687703@news.povray.org>
> Who can help me?
Have you tried Rex Cramer?  ;-)    [ Oh man, that reference is just so
80's ]
Subject: Povman
Date: 15 May 2006 12:40:59
Message: <4468af1b$1@news.povray.org>
Ehh... Who or what is Rex Cramer? Is it a render artist? Or a designer? And
since I am not English by birth, I am not sure what the attribute "80's"
means for a reference. Can you give me more information, Povman?
Thanks,
Sven
"POVMAN" <s### [at] acom> schrieb im Newsbeitrag news:44687703@news.povray.org...
> Have you tried Rex Cramer?  ;-) [ Oh man, that reference is just so 80's ]
Date: 15 May 2006 14:37:01
Message: <4468ca4d$1@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote in message
news:44669dac$1@news.povray.org...
> its small side the ground. The shape should have round corners.
You might be able to get something about the way you need it to be by using
blob having some negative strength (invisible) parts to shape a positive
strength sphere or cylinder piece, effectively framing it in and molding it
to that shape.
superellipsoid might be useful, too, as could be bicubic_patch, but if you
could try blob anyway to see if that would work okay.
Little example code, no need for camera:
#declare SeatCushion=
blob {
    threshold 0.4
    sphere {0,1,1}
    sphere {-1*x,1,-1}
    sphere {1*x,1,-1}
    sphere {-1*y,1,-1}
    sphere {1*y,1,-1}
    sphere {-1*z,1,-1}
    sphere {1*z,1,-1}
    pigment {rgb 1}
    scale <2,2,0.5>
union {
object {SeatCushion}
object {SeatCushion rotate 90*x translate <0,-1,-1>}
rotate 45*y translate <0.5,0.25,3.5>
light_source {<9,9,-9>,1}
