POV-Ray : Newsgroups : povray.general : heightfield height Server Time
19 Mar 2026 09:44:08 EDT (-0400)
  heightfield height (Message 1 to 3 of 3)
Subject: heightfield height
Date: 19 Apr 2006 16:30:27
Message: <44469de3$1@news.povray.org>
I am in the process of building a landscape.  I am using a USGS Dem image
for my heightfield. I there an easier way to determine the "y" value knowing
the "x" and "z" other than trial and error? Some objects are fencelines
built from spline curves. With the number of points needed for these curves,
the job becomes time intensive doing it by trial and error.
Thanks in advance, Dennis
Subject: Re: heightfield height
Date: 19 Apr 2006 17:31:07
Message: <4446ac1b$1@news.povray.org>
"trulayne" <tru### [at] newrrcom> wrote in message
news:44469de3$1@news.povray.org...
>knowing the "x" and "z" other than trial and error? Some objects are
>fencelines built from spline curves. With the number of points needed for
>these curves, the job becomes time intensive doing it by trial and error.
Hi Dennis,
You can use the 'trace' vector function to find a point on a surface. In
this case you would use it to shoot a ray straight downwards to intercept
the surface and return the coordinates of the point on the surface.
Alternatively I think you should be able to use the 'eval_pigment'
predefined function on the image to pick up the color and work out the
elevation from that.
Chris B.
Date: 19 Apr 2006 22:44:40
Message: <4446f598$1@news.povray.org>
Chris B, thank you very much. It is just what I needed. I can now generate
my spline curve in seconds into a text file and ready for use instead of
hours of boring trial and error.  :o)
Dennis
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:4446ac1b$1@news.povray.org...
> Hi Dennis,
> Regards,
> Chris B.
