POV-Ray : Newsgroups : povray.general : String to long message Server Time
11 Jun 2026 22:57:58 EDT (-0400)
  String to long message (Message 1 to 5 of 5)
Subject: String to long message
Date: 14 Mar 2006 10:32:57
Message: <4416e229$1@news.povray.org>
Hi NG
I have a ugly problem with "String to long"
I cant see ho to makes any long strings...
I have EAGLE 3D to display designed prints. I have the standard installation
windows.
the pov file look like this:
#local lgt1_pos_x = 0;
#local lgt1_pos_y = 0;
#local lgt1_pos_z = 0;
#local lgt1_intense =
179769000000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000;
#local lgt2_pos_x = 0;
#local lgt2_pos_y = 0;
#local lgt2_pos_z = 0;
#local lgt2_intense =
#local lgt3_pos_x = 0;
#local lgt3_pos_y = 0;
#local lgt3_pos_z = 0;
#local lgt3_intense =
#local lgt4_pos_x = 0;
#local lgt4_pos_y = 0;
#local lgt4_pos_z = 0;
#local lgt4_intense =
how to come from this long string?
any ideeas ?
thank's for help
Andrew Despont
Subject: Re: String to long message
Date: 14 Mar 2006 11:11:29
Message: <p5p5BHANpuFEFwF2@econym.demon.co.uk>
>Hi NG
If you need those really huge numbers you can use scientific notation
#local lgt1_intense = 17976900000000001e293;
(I think it's e293. I might have lost count)
Mike Williams
Gentleman of Leisure
Date: 15 Mar 2006 02:01:36
Message: <4417bbd0$1@news.povray.org>
Hi all
I have found the error
When i use a EAGLE PCB tu make a prov, the dimension of the board was not
set.
any more errors into the pov file.
I think it is an error from eagle 3D to pov converter!
I will publish this on to the Eagle newsgroup.
Thankyou all for help.
"Mike Williams" <nos### [at] econymdemoncouk> schrieb im Newsbeitrag
news:p5p### [at] econymdemoncouk...
>>Hi NG
> Mike Williams
Date: 15 Mar 2006 20:08:52
Message: <4418baa4@news.povray.org>
Mike Williams nous apporta ses lumieres en ce 14/03/2006 11:07:
>>Hi NG
i don't think that any PC can deal with values THAT large! The FPU just can't deal
with that.
WARNING: the crumsumpten of alcohol may Mack you tink you kan tpye reel gode
Date: 15 Mar 2006 23:47:17
Message: <ppu51OAerOGEFwcI@econym.demon.co.uk>
>>>Hi NG
>deal with that.
The FPU might not deal with that, but POV-Ray will quite happily parse
scene files that use such numbers. I did check that the POV parser
accepts the line
before I posted and the scene runs normally. I didn't ask POV to
actually do any arithmetic with the value, that would probably fail
depending on the details of that arithmetic.
E.g. str(lgt1_intense,-1,-1) returns "1.#INF00"
Mike Williams
