POV-Ray : Newsgroups : povray.general : Is this a bug ? #macro (sometimes not) returning values via output parameters Server Time
16 Oct 2025 14:05:10 EDT (-0400)
  Is this a bug ? #macro (sometimes not) returning values via output parameters (Message 1 to 4 of 4)
Subject: Is this a bug ? #macro (sometimes not) returning values via output parameters
Date: 12 Mar 2006 16:58:51
Message: <4414999b@news.povray.org>
I've just spend a few days trying to find a bug in my Povray code. Now I
believe something's wrong with the Povray engine (version
3.6.1b.icl8.win32).
Please take a look at the sample code below to see if I made a mistake. If
you can't find any, please try it on your own system and let me know what
results you found.
Kind regards,
Wil Koenen
Author     : Wil Koenen
Date       : 12 mar 2006
Description: Sample POVRAY code demonstrating an apparent bug.
The code was derived from a much, much larger program, by stripping it down
to the essentials. The problem is that a simple macro does not always change
its output parameter.
The error is deterministic, i.e. the same code produces the same error when
run many times. However, adding #debug directives, or other directives that
should not change the behaviour (e.g. #local dummy=0; ) may change the
behaviour (the iteration number at which the error occurs).
#macro f(xx)
   #declare xx=+1; // just a non-zero value
#declare i = 0;
#while (i< 10000)
        #declare a=-1;
        f(a)
        #local s=concat(
            "i = ", str(i,0,0),
            ", a=", str(a,0,0),
            "\n")
        #if (a>0)
                #debug s
        #else
                #error s
     #declare i=i+1;
Subject: Re: Is this a bug ? #macro (sometimes not) returning values via output parameters
Date: 12 Mar 2006 19:16:11
Message: <4414b9cb@news.povray.org>
It is a known bug and, AFAIK, should be adressed in the next update.
Tim
aka "Tim Nikias v2.0"
Date: 12 Mar 2006 22:24:31
Message: <4414e5ef$1@news.povray.org>
FYI, the workaround is to not pass variables by reference. If you need a
macro to return more than one value, have it return its results through
global variables; call the macro and read the variables it sets.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 13 Mar 2006 12:34:20
Message: <4415ad1c$1@news.povray.org>
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> wrote in
message news:4414b9cb@news.povray.org...
Indeed, I tested on 3.7.0.beta.11c.icl8-sse2.win32 and the problem was gone.
Thanks for your help.
Wil Koenen
