![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike,
I was tinkering with some applications of this code. I think that it says
that the spline will be evaluated "between control points 0 and 1". I
think however you're also doing it between the second and (n-1)th entry in
the code-- i.e., the code forces one to do a cubic spline. I was doing a
natural_spline and found that the last entry was always missing, and I
think this is the reason. I'm guessing one could change just a few
keystrokes in the file and be okay, but I'm wondering if you could help me
out before my brain explodes.
Thanks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Greg M. Johnson who wrote:
>Mike,
It does what it says. The spline is evaluated between the control points
that have values 0.0 and 1.0. It's not necessary to actually specify
control points at those locations, as long as the spline is validly
defined over the range 0.0 to 1.0.
The code accepts any type of spline.
#declare Track =
spline {
natural_spline
0, <10,1,0>,
0.5 <0,0,0>,
1, <10,-3,0>
For cubic splines there needs to be extra control points outside the 0-1
range because a cubic_spline is not validly defined in the first and
last sector.
#declare Track =
spline {
cubic_spline
-1, <12,2,0>,
0, <10,1,0>,
0.5 <0,0,0>,
1, <10,-3,0>,
2, <12,-5,0>
If you add control points after 1.0 in a natural or linear spline they
will be ignored.
#declare Track =
spline {
natural_spline
0, <10,1,0>,
0.5 <0,0,0>,
1, <10,-3,0>,
2, <12,-5,0> // this point is ignored
You can check that the macro is doing the right thing by plotting some
spheres along the spline, like this:
#declare A=0;
#while (A<1.0)
sphere{ Track(A),0.1 pigment {rgb x}}
#declare A=A+0.02;
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://flickr.com/photos/pterandon/79904280/
Okay, given a MyTrack linear spline that is declared from 0 to 1.
#declare n=0;
#while(n<1)
sphere{MyTrack(n), 1 pigment{green 1}}
#declare n=n+.05;
sphere{MyTrack(1), 1 pigment{green 1}}
#include "SweepMesh.inc"
object {
SweepMesh(MyTrack, MyWaist, 10,10, "",0.0)
uv_mapping
texture{MeshText}
As you can see in that attached image, the green spheres show that the
spline travels from 0 to 1.
But the SweepMesh doesn't reach the end.
>>Mike,
> #declare Track =
> spline {
> natural_spline
> 0, <10,1,0>,
> 0.5 <0,0,0>,
> 1, <10,-3,0>
> last sector.
> #declare Track =
> spline {
> cubic_spline
> -1, <12,2,0>,
> 0, <10,1,0>,
> 0.5 <0,0,0>,
> 1, <10,-3,0>,
> 2, <12,-5,0>
> will be ignored.
> #declare Track =
> spline {
> natural_spline
> 0, <10,1,0>,
> 0.5 <0,0,0>,
> 1, <10,-3,0>,
> #declare A=0;
> #while (A<1.0)
> #declare A=A+0.02;
> #end
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Try this:
Change the size of the arrays
#local Verts = array[(U+1)*(V+1)]
#local Norms = array[(U+1)*(V+1)]
#local UV = array[(U+1)*(V+1)]
The length of the while loop
#while (uu<=U)
And the information passed to BuildWriteMesh2
BuildWriteMesh2(Verts, Norms, UV, V, U, Filename)
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Try this:
I say: Thanks:
http://flickr.com/photos/pterandon/80330670
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
