POV-Ray : Newsgroups : povray.general : PPM troubles Server Time
12 Jun 2026 00:16:50 EDT (-0400)
  PPM troubles (Message 1 to 4 of 4)
Subject: PPM troubles
Date: 31 Jan 2006 12:12:00
Message: <43DFB487.81FA2B3E@joplin.com>
My POV3.6 will make PPM files ok, but it won't read them in a height feild. I
get:  Parse Error: Unsupported number of colors (0) in PPM image.
Does anyone else have that problem?
Have Fun!
Subject: Re: PPM troubles
Date: 31 Jan 2006 12:44:34
Message: <43dfa202$1@news.povray.org>
Last I tried to do this (pre-3.6) the PPM code was picky about the kind
and number of whitespace in the header. Try putting the depth and size
on the same line, or on separate lines, whichever it isn't now. Make
sure you have no commas, a newline instead of a space after the P6, etc.
    Crate & Barrel -
      Furnishing Video Games Since 1962!
Date: 31 Jan 2006 13:05:03
Message: <dro8jn$s1n$1@chho.imagico.de>
POV-Ray has troubles reading some unusual style PPM headers but can read
any files it generated itself.  If you have a PPM it can't read running
it through an image converter (like Imagemagick) before should help.
Latest MegaPOV contains a patch that makes the PPM reader much more
tolerant so any standard conforming PPM should work.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 31 Jan 2006 23:53:48
Message: <43E05906.C8822CB7@joplin.com>
I found the problem! I think!?
Besides having several bad PPM files that I was testing. I also had two versions
of POV running at the same time. I use POV3.5win to edit my C++ programs. I used
POV3.6 to make a test PPM. When I tried to make a height field it didn't work.
When I was shut down version 3.5 it did.
Have Fun!
