POV-Ray : Newsgroups : povray.general : Spherical object -> image map Server Time
30 Sep 2024 19:28:18 EDT (-0400)
  Spherical object -> image map (Message 1 to 4 of 4)
Subject: Spherical object -> image map
Date: 28 Nov 2005 16:13:26
Message: <438b72f6$1@news.povray.org>
I have created a fairly complex object which is essentially a sphere
with a bunch of stuff in it.  I've been working on animating the object,
and have achieved the effect which I want (distortions using the "blob"
command).  The only problem is I can only blob a sphere, rather then the
object itself.  I think that I may get the scene I desire by making an
image_map of the object, and mapping that onto the blob.  I tried this
using a map of the earth, and got essentially what I wanted.
Problem is, I don't know how to convert the object into an image_map.
Any ideas?
Thanx
Bryan
PS: In the animation the object moves through a small hole in a barrier,
  with a "dumbbell" shaped blob as the intermediary step.  You
essentially go sphere -> dumbbell -> sphere (on other side of wall).
Subject: Re: Spherical object -> image map
Date: 1 Dec 2005 09:50:15
Message: <438f0da7@news.povray.org>
"Bryan Heit" <bjh### [at] NOSPAMucalgaryca> wrote in message
news:438b72f6$1@news.povray.org...
>I have created a fairly complex object which is essentially a sphere with a
>bunch of stuff in it.  I've been working on animating the object, and have
>achieved the effect which I want (distortions using the "blob" command).
>The only problem is I can only blob a sphere, rather then the object
>itself.  I think that I may get the scene I desire by making an image_map
>of the object, and mapping that onto the blob.  I tried this using a map of
> Problem is, I don't know how to convert the object into an image_map. Any
> ideas?
> Thanx
> Bryan
> with a "dumbbell" shaped blob as the intermediary step.  You essentially
Hi Bryan,
When you say a 'sphere with a bunch of stuff in it', I'm not sure whether
you mean that there's stuff inside a translucent sphere or that there's
stuff stuck into the surface?
but I'll assume you mean the second one. Three potential approaches spring
to mind:
1.  You may be able to get somewhere with isosurfaces, which allow you to
define blob-like objects from objects other than just spheres. Mike Williams
has written the definitive isosurface tutorial. The section that describes
combining shapes in a blob-like way is at
http://www.econym.demon.co.uk/isotut/combine.htm.
2.  You may be able to stick your stuff into the blob object, using the
trace command to locate appropriate and corresponding points on the surface
of the blob as it distorts from one animation frame to the next.
3.  You might want to look at the cylindrical or spherical camera types in
the help to see if they might enable you to take 'snapshots' of  your object
that you could then wrap around a blob object. I've not used these camera
types myself, but it might be worth you experimenting to see whether they
seem to do what you need. My interpretation of the help is that you could
use a spherical camera type with the camera positioned at the centre of your
object (You may need to locate a single light source at the same point to
get even light distribution and eliminate shadows). It seems to imply that
you could take the generated image and project it straight onto a sphere
without distortion.
If these ideas don't hit the spot, then I suggest you post a small image on
povray.binaries.images to illustrate your problem.
Chris B.
Date: 1 Dec 2005 17:00:01
Message: <web.438f71b3a93231224289c7e80@news.povray.org>
> Any ideas?
If you mean that you want to render a spherical image map of the object from
the outside, you could try setting all the shapes that make up the object
to no_image, place a hollow mirror 1.0 sphere around the object, and use a
spherical camera at the center of the object.  This will give you a
spherical projection of the object as seen from the outside.
Date: 5 Dec 2005 10:02:08
Message: <43945670$1@news.povray.org>
>>Any ideas?
Thanx, worked perfectly!
Bryan
