POV-Ray : Newsgroups : povray.general : objects NEAR object Server Time
19 Mar 2026 15:11:40 EDT (-0400)
  objects NEAR object (Message 1 to 2 of 2)
Subject: objects NEAR object
Date: 21 Nov 2005 09:03:43
Message: <4381d3bf$1@news.povray.org>
How to place object near another object?
For example: I would like to place spheres, with random position and size,
near central irregular shaped object.
So, many objects should just touch the central object.
Subject: Re: objects NEAR object
Date: 21 Nov 2005 10:31:12
Message: <4381e840$1@news.povray.org>
size, near central irregular shaped object.
I think you can do this, in
pseudocode:
place your irregular object at the origin
   #include "shapes.inc"
   Center_Object ( IrregularObject, x+y+z )
get your random sphere position
   Position = <random X, random Y, random Z>
use the trace function to test where the location is relative to your
object.  use the negative of the position as the direction
   set Normal to <0,0,0>
   then
   SurfacePoint =
   trace ( IrregularObject, Position, <0,0,0>-Position, Normal )
   vlength(Normal) >? 0
   if no the location is inside the object, try a new Location
   if yes
   vlength(Position - SurfacePoint) >? Radius (of the sphere you want to
place)
   if yes, place the sphere at the Location
   if no, place the sphere at
   SurfacePoint + Normal*Radius  (so it is just touching the surface)
   you may now want to make further tests to make sure the sphere does
not intersect the surface in other directions from the sphere's center
