POV-Ray : Newsgroups : povray.general : Question on plane Syntax Server Time
28 Feb 2026 19:20:39 EST (-0500)
  Question on plane Syntax (Message 1 to 7 of 7)
Subject: Question on plane Syntax
Date: 9 Oct 2005 14:42:34
Message: <4349649a$1@news.povray.org>
The first three plane definitions pass through the parser. The fourth
generates an error. Why?
plane{
 <0,0,1>,1
 pigment{rgb<1,1,1>}
plane{
 <0,0,1>
 1
 pigment{rgb<1,1,1>}
plane{
 <0,0,1>,-1
 pigment{rgb<1,1,1>}
plane{
 <0,0,1>
 -1
 pigment{rgb<1,1,1>}
Kenneth Hutson
Subject: Re: Question on plane Syntax
Date: 9 Oct 2005 14:59:59
Message: <gB37vMApiWSDFwDn@econym.demon.co.uk>
>plane{
> <0,0,1>
> -1
> pigment{rgb<1,1,1>}
In places where a vector expression is expected, "1" is considered to be
the vector <1,1,1>. So "<0,0,1> -1" means <0,0,1> - <1,1,1>, with the
"-" being interpreted a the binary minus operator rather then the unary
minus. In order to avoid this interpretation, the comma is required.
plane{ <0,0,1> 1 pigment{rgb<1,1,1>}} is OK because the 1 cannot be
parsed as part of a vector expression.
plane{ <0,0,1> +1 pigment{rgb<1,1,1>}} will fail because the 1 is parsed
as part of a vector expression, so a comma would be required.
Mike Williams
Gentleman of Leisure
Date: 9 Oct 2005 15:05:01
Message: <web.434968689b6ef72cc8a538750@news.povray.org>
> plane{
>  <0,0,1>,1
>  pigment{rgb<1,1,1>}
> plane{
>  <0,0,1>
>  1
>  pigment{rgb<1,1,1>}
> plane{
>  <0,0,1>,-1
>  pigment{rgb<1,1,1>}
> plane{
>  <0,0,1>
>  -1
>  pigment{rgb<1,1,1>}
> Kenneth Hutson
4.plane :
You have forgotten "," : it must like that:
plane{
 <0,0,1>,
 -1
 pigment{rgb<1,1,1>}
Hasan...
Date: 9 Oct 2005 16:59:16
Message: <434984a4$1@news.povray.org>
Thank you sir!
Kenneth Hutson
Date: 10 Oct 2005 04:44:48
Message: <434a2a00$1@news.povray.org>
"Hasan3" <PRO### [at] Yahoocom> wrote in message
news:web.434968689b6ef72cc8a538750@news.povray.org...
>> plane{
>>  <0,0,1>,1
>>  pigment{rgb<1,1,1>}
>> plane{
>>  <0,0,1>
>>  1
>>  pigment{rgb<1,1,1>}
>> plane{
>>  <0,0,1>,-1
>>  pigment{rgb<1,1,1>}
>> plane{
>>  <0,0,1>
>>  -1
>>  pigment{rgb<1,1,1>}
>> Kenneth Hutson
> 4.plane :
> plane{
> <0,0,1>,
> -1
> pigment{rgb<1,1,1>}
> Hasan...
Hasan is correct.
Just in case you're wondering why the second example works, it's because
there's no positive or negative sign on the second parameter, so POV-Ray
assumes it's the second parameter and is happy.
With your 4th example the minus sign is taken as a mathematical operation
operating on the vector which evaluates to <-1,-1,0>. Then when POV-Ray
looks for the second parameter it can't find it and complains.
Chris B.
Date: 10 Oct 2005 04:50:34
Message: <434a2b5a@news.povray.org>
Whoops,
I responded before all of the messages downloaded, so I didn't see that Mike
already said that.
Date: 10 Oct 2005 13:29:24
Message: <434aa4f4$1@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:434a2b5a@news.povray.org...
> Whoops,
> Mike already said that.
Heh,
I was making the faulty assumption that (somehow) the hard return was
signalling that the second paramater was ready to be passed.
Thanks Chris.
