POV-Ray : Newsgroups : povray.general : Mud Cracks Server Time
1 Oct 2024 03:14:23 EDT (-0400)
  Mud Cracks (Message 1 to 4 of 4)
Subject: Mud Cracks
Date: 18 Aug 2005 01:49:21
Message: <43042161@news.povray.org>
Can anybody suggest a method procedural method, (Not using an image
file) to create a pattern of mud cracks such as one might find in the
desert?
I'd like to use an Isosurface for this, and I need to Use it in a
difference.
For example, see: http://pespmc1.vub.ac.be/Photos/MudCracks.jpg
A.D.B.
Subject: Re: Mud Cracks
Date: 18 Aug 2005 03:41:27
Message: <W1sZTBALqDBDFwOS@econym.demon.co.uk>
>desert?
>difference.
Here's something that might get you started in the right direction
camera { location  <0, 2, -4> look_at <0, 0.1, 0> angle 17}
light_source {<-100,100,100> colour rgb 1}
#declare P1=function{
  pigment{
    crackle
    colour_map {[0 rgb 0][0.08 rgb 1]}
    turbulence 0.2
#declare P2=function{
  pigment{
    crackle
    colour_map {[0 rgb 0][0.025 rgb 1]}
#declare Scale1=0.2;
#declare Scale2=0.07;
#declare Height1=0.03;
#declare Height2=0.01;
isosurface {
  function { y - P1(x/Scale1,0,z/Scale1).x*Height1
      - P2(x/Scale2,0,z/Scale2).x*Height2
  max_gradient 12
  contained_by{box{<-1,-0.01,-1><1,(Height1+Height2)*1.01,1>}}
  max_trace 4
  pigment {rgb .9}
It's not fast, and small changes to the Scale and Height parameters can
require significant changes to the max_gradient.
The "max_trace 4" isn't actually required in this scene, but you'll need
it when you use it in your difference.
Mike Williams
Gentleman of Leisure
Date: 18 Aug 2005 16:41:08
Message: <4304f264$1@news.povray.org>
There's a problem with simulating cracks with the crackle-pattern: with real
crackle-pattern gives an entirely different pattern which is more suitable for
things like mosaics.
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)                 // ZK http://www.povplace.com
Date: 18 Aug 2005 17:03:11
Message: <4304f78f$1@news.povray.org>
>>desert?
>>difference.
>   pigment{
>     crackle
>     turbulence 0.2
>   pigment{
>     crackle
> isosurface {
>   max_gradient 12
>   max_trace 4
>   pigment {rgb .9}
Hey Mike,
	Thanx, I'll try that.  The only problem I foresee is adjustment to my
scale.  I'm building my model in a scale of 1 unit = 1 inch.
A.D.B.
