POV-Ray : Newsgroups : povray.general : POV-Ray 3.7.beta.3 available Server Time
10 Sep 2025 11:36:27 EDT (-0400)
  POV-Ray 3.7.beta.3 available (Message 1 to 10 of 10)
Subject: POV-Ray 3.7.beta.3 available
Date: 1 May 2005 22:08:06
Message: <42758b86$1@news.povray.org>
POV-Ray 3.7.beta.3 is available from http://www.povray.org/beta/. This time
we have also included an SSE2 build for win32 users.
Changes between 3.7.beta.2 and 3.7.beta.3
Partial render (start col/row etc) now works
Fixed CSG merge issue reported in <42645c3b@news.povray.org>.
Added warning and better progress reporting to photons.
Some hollow media fixes.
Re-enabled alpha display in render window for windows port.
Fixed alpha bug reported in <web.426402d627a031d914107e060@news.povray.org>
Fixed no_image bug reported in <web.426402d627a031d914107e060@news.povray.org>
Changed default bounding threshold back to 3 as per v3.6.
Fixed alpha inversion bug in BMP, Targa, and PNG file reading/writing.
Fixed crash mentioned in <42689685@news.povray.org>.
Fixed noise generator default issue reported in <426898db@news.povray.org>.
Fixed irid problem reported in <42680b39@news.povray.org>.
Fix for area light problem from Massimo Valentini.
Made quick_colour work as it should.
-- Chris
Subject: Re: POV-Ray 3.7.beta.3 available
Date: 1 May 2005 23:30:40
Message: <42759ee0$1@news.povray.org>
Nice splash =)
(Actually, not too crazy about the text on it. Seems every time I see the
words "POV-Ray," they're in a different font/color/size. Shouldn't there be
a consistent look, that fits with the logo?)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 1 May 2005 23:51:58
Message: <4275a3de@news.povray.org>
  The difference in speed between the pvengine.exe and the pvengine-sse2.exe
is quite remarkable at least in my pentium4 machine. The latter is more
than twice as fast as the former.
  Incredible what a big difference the choice of a compiler can have... :)
Date: 2 May 2005 08:07:16
Message: <427617f4$1@news.povray.org>
> -- Chris
Using the SSE2 build, I still see weird artifacts in the beta 3 version.
I have posted to povray.betatest.binaries the arealight sample rendered
in 3.6 vs 3.7b3, this was rendered using the arealit1.pov sample scene.
~Mike
Things! Billions of them!
Date: 3 May 2005 05:34:50
Message: <427745ba@news.povray.org>
Actually even more so when I discover that I accidentally included the MSVC
compile for pvengine.exe. Sorry about that, new binary on the way now.
-- Chris
Date: 4 May 2005 02:50:11
Message: <427870a3$1@news.povray.org>
Really fantastic improvement for pentium4!
Any optimization for AMD too...?
Paolo
MSVC
> -- Chris
Date: 4 May 2005 09:21:17
Message: <4278cc4d$1@news.povray.org>
The sse2 version should run well on AMD processors that support it. Or you
could run Windows XP 64 on the AMD64 and see it fly* ;-)
-- Chris
* apart from the fact that it has SSE2, the AMD64 also had additional
registers which allow for a parameter-passing in register scheme and more
efficient code in general. this improves performance noticably.
Date: 4 May 2005 09:55:01
Message: <d5ak54$u49$1@chho.imagico.de>
BTW since you have both Windows and Linux running on AMD64 IIRC - did
you ever make a direct comparison (with the 3.6 codebase) of the
optimized Windows 64bit build with the gcc build on Linux?  The
performance gain of 32->64bit on Linux is significant but i don't have
the direct comparison with Windows.
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 6 May 2005 06:21:48
Message: <427b453c$1@news.povray.org>
Ok, ok, i *must* upgrade my processor...
Paolo
> -- Chris
Date: 17 May 2005 10:54:04
Message: <428a058c$1@news.povray.org>
No, I don't think I did.
-- Chris
PS only just saw this posting because you (or your newsreader) removed the
beta-test group from the newsgroup line (I wasn't following this thread in
p.general since it was also appearing in p.beta-test).
