POV-Ray : Newsgroups : povray.general : Chief Architect-2 Server Time
1 Mar 2026 02:27:23 EST (-0500)
  Chief Architect-2 (Message 1 to 4 of 4)
Subject: Chief Architect-2
Date: 29 Mar 2005 18:06:14
Message: <4249df66$1@news.povray.org>
How do I suppose to define the following items in POVRAY:
1-Radiosity parameters
2-Daytime or night time.
3-Using the soft shadows.
4-Anti-Aliasing parameters.
5-Diffuse sunlight.
6- Direct sunlight.
Thanks.
A-Design
Subject: Re: Chief Architect-2
Date: 29 Mar 2005 19:43:13
Message: <4249f621$1@news.povray.org>
A-Design nous apporta ses lumieres en ce 2005-03-29 18:06:
With a radiosity block in the global_settings block. 3.3.4
The simplest:global_settings{radiosity{}}
Adjust the position and intencity of your light(s). Take a look at lightsys.inc
area_light 3.4.7.5
in the light_source deffinition, add
area_light x*VAL, z*VAL, XSamples, ZSamples adaptive 0 circular orient
VAL define the extent of the light
Samples define how many subelements along each axix
adaptive prevent the use of all samples when not needed, gaining speed. change if you
get artefacts.
circular make the light a circle (otherwize, it's square)
orient ensure that it's always properly oriented
quick starting point: +a0.3	3.1.2.8.4
> 5-Diffuse sunlight.
use radiosity and maybe some scathering media	3.6.2
> 6- Direct sunlight.
anything directly lighted by the light acting as the sun
> Thanks.
> A-Design
The numbers relate to the documentation.
Date: 30 Mar 2005 03:41:42
Message: <424a6646$1@news.povray.org>
Thanks Alain.
"Alain" <ele### [at] netscapenet> wrote in message
news:4249f621$1@news.povray.org...
> lightsys.inc
> area_light 3.4.7.5
> change if you get artefacts.
>> 5-Diffuse sunlight.
>> 6- Direct sunlight.
>> Thanks.
>> A-Design
> Alain
Date: 19 Apr 2005 01:09:20
Message: <42649280$1@news.povray.org>
Thank you Alain.
> lightsys.inc
> area_light 3.4.7.5
>> 5-Diffuse sunlight.
>> 6- Direct sunlight.
>> Thanks.
>> A-Design
> Alain
