POV-Ray : Newsgroups : povray.general : custom blendfunction? Server Time
10 Sep 2025 14:59:03 EDT (-0400)
  custom blendfunction? (Message 1 to 3 of 3)
Subject: custom blendfunction?
Date: 9 Mar 2005 13:30:03
Message: <422f40ab@news.povray.org>
Is there a way to define a custom blend-function for patterns ?
I can't do it with function's, because it's the aoi-pattern which cannot be used
inside a function.
cu!
Subject: Re: custom blendfunction?
Date: 9 Mar 2005 14:11:00
Message: <cjameshuff-30D709.14105909032005@news.povray.org>
In article <422f40ab@news.povray.org>,
> used inside a function.
Do you mean a custom waveform function? You could imitate doing so by
applying the inverse of the function to the color map t-values. You may
have to add entries to the color map to get reasonably correct results,
though.
One of the patches I recently released allows the aoi pattern to be
written as a function...though you probably can't wait for that to be
added to MegaPOV.
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 9 Mar 2005 14:20:07
Message: <422f4c67@news.povray.org>
"Christopher James Huff" <cja### [at] gmailcom> wrote in message
news:cjameshuff-30D709.14105909032005@news.povray.org...
> though.
> added to MegaPOV.
not really :)
but I fixed it another way.
In case anyone's interested, here's my solution to my problem.
First the problem :)  I'm trying to simulate media-effects with aoi, as probably
everybody now already knows :)  I also want to make things have a glow-effect.
With media, that's quite easy to simulate:
sphere {0,1 pigment {rgbt 1} interior {media {emission 1 density {spherical
poly_wave 5}}}}
(it's the poly_wave that does the trick)
But with aoi, it's more complicated!  To simulate a simple media-effect using
aoi, you need something like the following:
sphere {0,1 pigment {aoi color_map {[0 rgb 1][.5 rgbt 1]}}}
The color_map is needed because aoi gives 0 when the normal is pointed towards
the camera, .5 when it's perpendicular to the camera and 1 when it's pointing in
the same direction as the camera, so everything between .5 and 1 is of no
importance and should be left out.  However, because of that, poly_wave will not
behave the same way as with media: the .5 in the color_map will 'shift' and will
no longer correspond to normals perpendicular to the camera.
my solution:
sphere {
  0,1
    aoi
    #declare P=.5;
    color_map {
      [0 rgb 1]
      [pow(.5,P) rgbt 1]
    poly_wave P
very simple, I just didn't think of it :)
cu!
