POV-Ray : Newsgroups : povray.general : Render time for a city macro : mesh vs. pigment_map for detail. Server Time
1 Mar 2026 04:00:46 EST (-0500)
  Render time for a city macro : mesh vs. pigment_map for detail. (Message 1 to 5 of 5)
Subject: Render time for a city macro : mesh vs. pigment_map for detail.
Date: 1 Mar 2005 21:58:32
Message: <42252bd8$1@news.povray.org>
Hello, I've been thinking of writing my own city macro.  There are two basic
ways I can think of adding lots of detail.  I'm wondering which means of
adding detail would render faster:
i) boxes (or a mesh2 which is a simple, say 12-triangle box)  which show
detail (windows, etc.) by means of a really complicated pigment_map.
ii) mesh2's for every single detail: windows, window frames, etc.  These
however would probably have much simpler textures.
thanks for any educated opinions.
Subject: Re: Render time for a city macro : mesh vs. pigment_map for detail.
Date: 2 Mar 2005 00:58:09
Message: <422555f1$1@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:42252bd8$1@news.povray.org...
> I'm wondering which means of adding detail would render faster:
I don't know but I would like to know as well.  I'm also interested in
adding 'interior' details so that maybe we could see into the closer windows
a little bit.  In my case, that may preclude mesh2, guess I'd have to think
about it.
Did you see my 'nice view' WIP in P.B.I?  I pretty extensivly modified Chris
Colefax's city, and am trying to add more detail now.
One thing I ran into is that the Colefax city buidings are 'narrow' meaning
if you look at the height of a 'floor' they are pretty small square footage
wise. This caused me major consternation while I was doing the last Anim
IRTC; when one of my test renders got to 'ground floor' I suddenly realized
the buildings were all about 3x normal 'height'.  Anyway, my fix for this
was to modify the macro so that the same type of building 'only' would be
generated on one city block, and that there was 0 gap between buildings. You
can see this in the WIP I posted, I used 3x3 grids, and I plan on extending
that some.
Thinking about this process, I think it could be used to add a lot more
detail.  If you had a 3x3 or 4x4 'single building' made of primitives, the
corners could look different than the 'middle'.  You could stagger the
various sides so that you could do some interesting skylines.  For example,
a quick google search for 'skyline' shows that big buildings typically have
repeating patters but taper some going up:
http://timmerca.com/data/1000/articles/1400/1695-original.jpg
Look at the 5th building from the left, for example, it could be done with a
8x8 grid with alternating roof heights stepping up.
This isn't as usefull for me, my concept of having a dome of air is that the
Martians will build RIGHT UP to the edge of the dome, with fresh air and
normal temperatures being so scarce, but it could be very usefull for
Manahatten type cities, or with some extensions usefull fo rme.
I've got my macro's all ripped up at the moment, I'm adding a 'tram slot'
for the Mars city transportation and I'm getting some weird results, I have
to debug it some.  I can post them when I get it working again if you'd
like, maybe we can fiddle with as a group process, if Chris is OK with that.
             == John ==
Date: 2 Mar 2005 01:00:05
Message: <42255665$1@news.povray.org>
Did you see my 'nice view' WIP?  I pretty extensivly modified Chris
about it.
that some.
             == John ==
Date: 3 Mar 2005 13:49:17
Message: <42275c2d@news.povray.org>
If you want to make any slow render (test or final), you can mail me; I have
a 3000MHz computer with 512MB ram.
> basic ways I can think of adding lots of detail.  I'm wondering which
Date: 4 Mar 2005 23:23:08
Message: <4229342c$1@news.povray.org>
Thanks for the kind offer. I am however occasionally doing 1000 frame
animations, and once I get into production, I do a new render of the set
each night.  Keeping track of all these files would be a logistical
nightmare.
"Nicolas Alvarez" <nic### [at] gmailbestwebmailcom> wrote in message
news:42275c2d@news.povray.org...
> have
